[cgma-dev] CGM 13.1 and PyTAPS
    Paul Wilson
    wilsonp at engr.wisc.edu
    Mon Dec 16 07:49:21 CST 2013
Hi Andy, Iulian,
I've added Anthony Scopatz into this conversation, as he has a growing
interest in PyTAPS.  He is also a python expert.  I'm not sure if he is
on the CGMA list yet.
<nudge>Tim was also planning to move it to bitbucket soon (last month?)
to facilitate collaborative development </nudge>
Paul
On 12/13/2013 12:22 PM, Iulian Grindeanu wrote:
> It looks like in python there is no equivalent to ifdefs.
> We could simply use an if statement, but we need to have something
> different for cgm >= 13
> Python is an interpreted language, and we can do something like this:
> |import  os
> if  os.name==  "posix":
>      def  foo(x):
>          return  x*  x
> else:
>      def  foo(x):
>          return  x+  42
> Now, we need to export somehow the version from iGeom.h / iBase.h, to
> be visible in pytaps.
> Another solution is to create an svn branch for pytaps too (I prefer
> not to, because there is not much difference, so far) And as long as
> iGeom.h does not change, we do not really need different branches.
>  Any suggestions?
> Iulian
>     Hello,
>     Does anybody know how to do ifdefs in python? Or something similar?
>     This is what I am using for pytaps built with cgm trunk (actually,
>     cgm/tags/13.1.1)
>     (you should be able to apply this patch on pytaps source, and use
>     it also for trunk version)
>     Iulian
>         HI
>         I think the iMesh implmentation in CGM13.1 is mismatched for
>         the PyTAPS
>         1.4, PyTAPS 1.4 failed to build when using CGM 13.1, but is
>         fine with
>         12.2. The error messages are all code issues regarding mismatched
>         arguments to functions, passing ints when it should be doubles
>         and so on.
>         I figured this should be reported here since I couldnt find
>         PyTAPS dev
>         Thanks
>         Andy
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131216/8fa65b40/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131216/8fa65b40/attachment.bin>
More information about the cgma-dev
