[cgma-dev] CGM 13.1 and PyTAPS
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Fri Dec 13 10:21:42 CST 2013
Hello,
Does anybody know how to do ifdefs in python? Or something similar?
This is what I am using for pytaps built with cgm trunk (actually, cgm/tags/13.1.1)
(you should be able to apply this patch on pytaps source, and use it also for trunk version)
Iulian
----- Original Message -----
| HI
| I think the iMesh implmentation in CGM13.1 is mismatched for the
| PyTAPS
| 1.4, PyTAPS 1.4 failed to build when using CGM 13.1, but is fine with
| 12.2. The error messages are all code issues regarding mismatched
| arguments to functions, passing ints when it should be doubles and so
| on.
| I figured this should be reported here since I couldnt find PyTAPS
| dev
| Thanks
| Andy
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131213/b61274d4/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131213/b61274d4/attachment.bin>
More information about the cgma-dev
