[cgma-dev] Opencascade directory missing from link line
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Nov 29 15:53:05 CST 2013
../configure --prefix=/home/jed/usr/itaps-ompi --enable-debug --enable-shared --disable-fortran --with-mpi --with-occ=/opt/opencascade CC=mpicc CXX=mpicxx FC= F77=
The link line below attempts -lTKernel, but does not use any linker flags for /opt/opencascade/lib.
Making all in util
make[2]: Entering directory '/home/jed/src/cgm/bompi-occ/util'
/bin/sh ../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -g   -o libcubit_util.la -rpath /home/jed/usr/itaps-ompi/lib AllocMemManagersList.lo AppUtil.lo ArrayBasedContainer.lo CpuTimer.lo Cubit2DPoint.lo CubitBox.lo CubitCollection.lo CubitContainer.lo CubitCoordinateSystem.lo CubitDynamicLoader.lo CubitEntity.lo CubitEventDispatcher.lo CubitFile.lo CubitFileFEModel.lo CubitFileIOWrapper.lo CubitFileMetaData.lo CubitFileSimModel.lo CubitFileUtil.lo CubitMatrix.lo CubitMessage.lo CubitObservable.lo CubitObserver.lo CubitPlane.lo CubitSparseMatrix.lo CubitStack.lo CubitString.lo CubitTransformMatrix.lo CubitUndo.lo CubitUtil.lo CubitVector.lo DIntArray.lo DLList.lo DynamicArray.lo GMem.lo GetLongOpt.lo GfxDebug.lo IntersectionTool.lo MemoryBlock.lo MemoryManager.lo ParamCubitPlane.lo PlanarParamTool.lo Queue.lo RandomMersenne.lo SDLList.lo SettingHandler.lo SettingHolder.lo StubProgressTool.lo TDUPtr.lo TextProgressTool.lo ToolData.lo ToolDataUser.lo Tree.lo TtyProgressTool.lo GlobalCommandFeedback.lo CubitProcess.lo CubitInstrumentation.lo  -ldl  -lTKernel -lm
libtool: link: mpicxx  -fPIC -DPIC -shared -nostdlib /usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/../../../../lib/crti.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/crtbeginS.o  .libs/AllocMemManagersList.o .libs/AppUtil.o .libs/ArrayBasedContainer.o .libs/CpuTimer.o .libs/Cubit2DPoint.o .libs/CubitBox.o .libs/CubitCollection.o .libs/CubitContainer.o .libs/CubitCoordinateSystem.o .libs/CubitDynamicLoader.o .libs/CubitEntity.o .libs/CubitEventDispatcher.o .libs/CubitFile.o .libs/CubitFileFEModel.o .libs/CubitFileIOWrapper.o .libs/CubitFileMetaData.o .libs/CubitFileSimModel.o .libs/CubitFileUtil.o .libs/CubitMatrix.o .libs/CubitMessage.o .libs/CubitObservable.o .libs/CubitObserver.o .libs/CubitPlane.o .libs/CubitSparseMatrix.o .libs/CubitStack.o .libs/CubitString.o .libs/CubitTransformMatrix.o .libs/CubitUndo.o .libs/CubitUtil.o .libs/CubitVector.o .libs/DIntArray.o .libs/DLList.o .libs/DynamicArray.o .libs/GMem.o .libs/GetLongOpt.o .libs/GfxDebug.o .libs/IntersectionTool.o .libs/MemoryBlock.o .libs/MemoryManager.o .libs/ParamCubitPlane.o .libs/PlanarParamTool.o .libs/Queue.o .libs/RandomMersenne.o .libs/SDLList.o .libs/SettingHandler.o .libs/SettingHolder.o .libs/StubProgressTool.o .libs/TDUPtr.o .libs/TextProgressTool.o .libs/ToolData.o .libs/ToolDataUser.o .libs/Tree.o .libs/TtyProgressTool.o .libs/GlobalCommandFeedback.o .libs/CubitProcess.o .libs/CubitInstrumentation.o   -lTKernel -L/usr/lib/openmpi -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/../../.. -lmpi_cxx -lmpi -ldl -lhwloc -lstdc++ -lm -lpthread -lc -lgcc_s /usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/crtendS.o /usr/lib/gcc/x86_64-unknown-linux-gnu/4.8.2/../../../../lib/crtn.o    -Wl,-soname -Wl,libcubit_util.so.0 -o .libs/libcubit_util.so.0.0.0
/usr/bin/ld: cannot find -lTKernel
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131129/ff6e30d0/attachment.pgp>
More information about the cgma-dev
