[cgma-dev] r6103 - in cgm/tags/13.1.0: . geom
    janehu at mcs.anl.gov
    Fri Nov 22 13:46:32 CST 2013
Author: janehu
Date: 2013-11-22 13:46:32 -0600 (Fri, 22 Nov 2013)
New Revision: 6103
Added:
   cgm/tags/13.1.0/cgm_version.h
Modified:
   cgm/tags/13.1.0/Makefile.am
   cgm/tags/13.1.0/geom/GeometryQueryTool.cpp
   cgm/tags/13.1.0/geom/GeometryQueryTool.hpp
Log:
Moved cgm version to a separate header file.
Modified: cgm/tags/13.1.0/Makefile.am
--- cgm/tags/13.1.0/Makefile.am	2013-11-22 17:56:35 UTC (rev 6102)
+++ cgm/tags/13.1.0/Makefile.am	2013-11-22 19:46:32 UTC (rev 6103)
@@ -11,6 +11,7 @@
 lib_LTLIBRARIES = libcgm.la
+libcgm_la_includedir = $(includedir)
 if ENABLE_igeom
   igeom_DIR = itaps
 else
@@ -55,6 +56,7 @@
 libcgm_la_SOURCES =
+libcgm_la_include_HEADERS = cgm_version.h
 # By default, cmg.make will define these to $(srcdir).  We
 # want to override that during the INSTALL of the file so
 # that the correct values are set (e.g. if someone does
Added: cgm/tags/13.1.0/cgm_version.h
--- cgm/tags/13.1.0/cgm_version.h	                        (rev 0)
+++ cgm/tags/13.1.0/cgm_version.h	2013-11-22 19:46:32 UTC (rev 6103)
@@ -0,0 +1,2 @@
+#define  CGM_MAJOR_VERSION  13
+#define  CGM_MINOR_VERSION  1
Modified: cgm/tags/13.1.0/geom/GeometryQueryTool.cpp
--- cgm/tags/13.1.0/geom/GeometryQueryTool.cpp	2013-11-22 17:56:35 UTC (rev 6102)
+++ cgm/tags/13.1.0/geom/GeometryQueryTool.cpp	2013-11-22 19:46:32 UTC (rev 6103)
@@ -92,9 +92,6 @@
 DLIList<int> GeometryQueryTool::uidsOfImportingEnts;
 int GeometryQueryTool::entitiesMergedAway = 0;
-const int GeometryQueryTool::CGM_MAJOR_VERSION = 13;
-const int GeometryQueryTool::CGM_MINOR_VERSION = 1;
 #ifndef CAT
   // Keep checking bounding box and use internal surf check for Sandia
   CubitBoolean GeometryQueryTool::bboxMergeTest = CUBIT_TRUE;
Modified: cgm/tags/13.1.0/geom/GeometryQueryTool.hpp
--- cgm/tags/13.1.0/geom/GeometryQueryTool.hpp	2013-11-22 17:56:35 UTC (rev 6102)
+++ cgm/tags/13.1.0/geom/GeometryQueryTool.hpp	2013-11-22 19:46:32 UTC (rev 6103)
@@ -1114,9 +1114,6 @@
   int maxPersistentRefEdgeId;
   int maxPersistentRefVertexId;
More information about the cgma-dev
