[cgma-dev] r6082 - in cgm/branches/merge-cubit14.0: .	compat	compat/new geom itaps test
    Timothy J. Tautges
    tautges at mcs.anl.gov
    Fri Nov  1 14:41:56 CDT 2013
Cool!  Good job Jane!
-------- Original message --------
Date: 11/01/2013  12:45 PM  (GMT-06:00)
To: cgma-dev at mcs.anl.gov
Subject: [cgma-dev] r6082 - in cgm/branches/merge-cubit14.0: . compat	compat/new geom itaps test
Author: janehu
Date: 2013-11-01 12:45:08 -0500 (Fri, 01 Nov 2013)
New Revision: 6082
Added:
   cgm/branches/merge-cubit14.0/compat/
   cgm/branches/merge-cubit14.0/compat/Makefile.am
   cgm/branches/merge-cubit14.0/compat/new/
   cgm/branches/merge-cubit14.0/compat/new/new.h
   cgm/branches/merge-cubit14.0/geom/CubitCompat.cpp
   cgm/branches/merge-cubit14.0/geom/CubitCompat.h.in
   cgm/branches/merge-cubit14.0/geom/CubitCompat.hpp
   cgm/branches/merge-cubit14.0/test/cylinders.cpp
   cgm/branches/merge-cubit14.0/test/s5.sat
   cgm/branches/merge-cubit14.0/test/s5.stp
   cgm/branches/merge-cubit14.0/test/spheres.cpp
Modified:
   cgm/branches/merge-cubit14.0/itaps/Makefile.am
   cgm/branches/merge-cubit14.0/itaps/iGeom_CGMA.cc
   cgm/branches/merge-cubit14.0/test/Makefile.am
   cgm/branches/merge-cubit14.0/test/r_w.cpp
   cgm/branches/merge-cubit14.0/test/subtract.cpp
Log:
Added missing files; Removed some of the warnings; Passed make check for cubit shared, occ static and shared builds. Ready to move to bitbucket.
Added: cgm/branches/merge-cubit14.0/compat/Makefile.am
--- cgm/branches/merge-cubit14.0/compat/Makefile.am	                        (rev 0)
+++ cgm/branches/merge-cubit14.0/compat/Makefile.am	2013-11-01 17:45:08 UTC (rev 6082)
@@ -0,0 +1 @@
+EXTRA_DIST = new/new.h
Added: cgm/branches/merge-cubit14.0/compat/new/new.h
--- cgm/branches/merge-cubit14.0/compat/new/new.h	                        (rev 0)
+++ cgm/branches/merge-cubit14.0/compat/new/new.h	2013-11-01 17:45:08 UTC (rev 6082)
@@ -0,0 +1,11 @@
+#include <new>
+// According to section 18.4 of the 2005-10-19 working draft
+// of the C++ Standard (Doc no: N1905=05-0165), these are the
+// symbols defined in the <new> header.
+using std::bad_alloc;
+using std::nothrow_t;
+using std::nothrow;
+using std::new_handler;
+using std::set_new_handler;
Added: cgm/branches/merge-cubit14.0/geom/CubitCompat.cpp
--- cgm/branches/merge-cubit14.0/geom/CubitCompat.cpp	                        (rev 0)
+++ cgm/branches/merge-cubit14.0/geom/CubitCompat.cpp	2013-11-01 17:45:08 UTC (rev 6082)
@@ -0,0 +1,93 @@
+#include "CubitCompat.h"
+#include "CubitCompat.hpp"
+#include "GeometryQueryTool.hpp"
+#include <string.h>
+#define CUBIT_COMPAT_FT_ELIF(TYPE) \
+  else if (!strcmp(file_type,#TYPE)) \
+    return TYPE ## _TYPE
+static Model_File_Type
+CubitCompat_file_type( const char* file_type )
+  if (!file_type)
+    return MFT_NOT_DEFINED;
+  CUBIT_COMPAT_FT_ELIF(ACIS);
+  CUBIT_COMPAT_FT_ELIF(ACIS_SAT);
+  CUBIT_COMPAT_FT_ELIF(ACIS_SAB);
+  CUBIT_COMPAT_FT_ELIF(ACIS_DEBUG);
+  CUBIT_COMPAT_FT_ELIF(IGES);
+  CUBIT_COMPAT_FT_ELIF(CATIA);
+  CUBIT_COMPAT_FT_ELIF(STEP);
+  CUBIT_COMPAT_FT_ELIF(PROE);
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131101/ba64c090/attachment.html>
More information about the cgma-dev
