[cgma-dev] r6072 - cgm/trunk/test
    janehu at mcs.anl.gov
    Mon Oct  7 11:14:32 CDT 2013
Author: janehu
Date: 2013-10-07 11:14:32 -0500 (Mon, 07 Oct 2013)
New Revision: 6072
Added:
   cgm/trunk/test/spheres.cpp
Modified:
   cgm/trunk/test/Makefile.am
Log:
Added one testcase, spheres for multi-volume body webcut operation.
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2013-10-07 16:12:57 UTC (rev 6071)
+++ cgm/trunk/test/Makefile.am	2013-10-07 16:14:32 UTC (rev 6072)
@@ -16,7 +16,7 @@
   TESTS += webcut hollow_acis brick_acis merge_acis AngleCalc_acis CreateGeometry_acis GraphicsData_acis
 else
 if WITH_CUBIT
-  TESTS += webcut merge_acis brick_acis
+  TESTS += webcut merge_acis brick_acis spheres
 else
 if DEV
   TESTS += modify makept
@@ -25,7 +25,7 @@
 endif
 if build_OCC
-  TESTS += attribute_to_file loft offset_curves point_project imprint_bug subtract test_occ brick_occ merge_occ r_w operation section AngleCalc_occ  CreateGeometry_occ GraphicsData_occ brick_facet merge_facet
+  TESTS += attribute_to_file loft offset_curves point_project imprint_bug subtract test_occ brick_occ merge_occ r_w operation section AngleCalc_occ  CreateGeometry_occ GraphicsData_occ brick_facet merge_facet spheres
 endif
 check_PROGRAMS = $(TESTS)
@@ -44,6 +44,7 @@
 libcgm_test_la_SOURCES = TestUtilities.hpp \
                          TestUtilities.cpp
+spheres_SOURCES = spheres.cpp
 webcut_SOURCES = webcut.cpp
 hollow_acis_SOURCES = hollow_acis.cpp
 makept_SOURCES = makept.cpp
@@ -160,6 +161,7 @@
         pyramid.occ \
         fillet.occ \
         curves.brep \
+        spheres.sat \
 	mmgr.log
Added: cgm/trunk/test/spheres.cpp
--- cgm/trunk/test/spheres.cpp	                        (rev 0)
+++ cgm/trunk/test/spheres.cpp	2013-10-07 16:14:32 UTC (rev 6072)
@@ -0,0 +1,74 @@
+#undef NDEBUG
+#include <cassert>
+#include "GeometryModifyTool.hpp"
+#include "GeometryQueryTool.hpp"
+#include "Body.hpp"
More information about the cgma-dev
