[cgma-dev] Switching unique IDs to RFC4122 UUIDs
Clinton Stimpson
clinton at elemtech.com
Tue Sep 24 10:43:01 CDT 2013
On Monday, September 23, 2013 03:07:29 PM Tim Tautges wrote:
> [cc'ing cubit-dev, since they will also want to weigh in on this...]
> On 09/20/2013 04:08 PM, David Thompson wrote:
> > Hi all,
> > I am looking into switching CGMA's IDs from ints (4-8 bytes, signed) to
> > RFC4122-style UUIDs (16 bytes, unsigned) so that cross-references across
> > multiple large models are much less likely to have duplicate IDs.
> While I think this is worth considering (and doing, if it were just CGM),
> I'm not sure it's so critical for file operations. Large models are indeed
> likely to have conflicting ids with other large files, but those could be
> handled by keeping track of the current file you're reading and the
> entities read by each file (not efficient, I know, but simple to
> implement).
> > One problem I am having is that CGMA performs math (addition/subtraction)
> > on UUIDs in places. For instance, SubEntitySet::renumerate,
> > CAEntityId::actuate, and PartitionEngine::restore_from_attrib all do some
> > kind of math (increment/decrement) on UIDs. This is not supported by any
> > UUID implementation I'm aware of.
> Looking at CAEntityId::actuate, and the GSaveOpen::get_id_inc, it appears
> that this increment is used in place of a file id or indicator (haven't
> checked that to be sure, but I'd be very surprised if that wasn't the
> case), but that's for entity ids, not for unique ids. SubEntitySet's use
> seems like EntityId, not UID; same goes for
> PartitionEngine::restore_from_attrib.
> > Also, CGMA compares/swaps CAUniqueId and TDUniqueId values, which I
> > thought lived in different "namespaces" (sequential integers for
> > CAUniqueId and random integers for TDUniqueId). Was I wrong to think
> > this? If not, why does CAEntityId add the same id_inc to both its own ID
> > and its merge-partner's (which appears to be obtained in some places
> > using TDUniqueId::find_td_unique_id)?
> Here I think you're wrong, the unique id and entity id are different
> concepts, and the find_td_unique_id in CAEntityId is used strictly with
> UIDs and not with entity ids.
> To summarize, while I think it would be useful to use a standards-compliant
> UUID, in practice I'm guessing it's going to be difficult to motivate the
> Cubit project to change what they do to accomplish this, even if you/we
> implement all the changes in CGM and below. Cubit guys, please chime in
> here. It appears to me that GSaveOpen was probably meant to do what a true
> UUID change would, that is, guarantee different UUID spaces in different
> files, alas they solved it a different way.
Keeping track of the current file and entities being read is a good approach.
Even if you have a better unique id (e.g. RFC 4122), you will still have
collisions when importing the same file twice. In that case, GSaveOpen serves
a purpose to help reference entities local to the current file being imported,
which UUIDs cannot help with.
Aside from that, in the past, a couple of us have informally talked about
wanting to use a standard UUID in CGM to reduce collisions. I think its a
good idea.
By the way, its nice to see Kitware using CGM. I'm curious what its being
used for.
Clinton Stimpson
Elemental Technologies, Inc
Computational Simulation Software, LLC
www.csimsoft.com
More information about the cgma-dev
