[cgma-dev] Observer question?
    David Thompson
    david.thompson at kitware.com
    Mon Jul 22 16:20:20 CDT 2013
Hi Tim,
>> ... for tracking persistent geometry across operations ... Would you advise adding UUIDs as attributes ...?
> No; you'd get exactly the same results.  We hang an attribute on the engine entities pointing to the CGM entities, then after the operation, see what's left, and remove the CGM entities that are no longer referenced.  So in a sense, we only get "before" and "after" pictures, not "during" pictures.
I think we're in violent agreement; if there is no "during" picture, then I should just fetch entities "after" which have the same entityId as they did "before." Is that what you meant?
	David
More information about the cgma-dev
