[cgma-dev] r6044 - cgm/trunk/util
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Thu May 23 11:25:08 CDT 2013
so make distcheck works in a cubit based build, but it does not yet on a occ based build. (some other files are missing from the ".._SOURCE" variables in some Makefile.am's).
It is relatively easy to fix, I will get to it later today.
Iulian
----- Original Message -----
| Thanks Iulian, I figured you'd be able to fix it that quickly!
| - tim
| On 05/23/2013 12:25 AM, iulian at mcs.anl.gov wrote:
| > Author: iulian
| > Date: 2013-05-23 00:25:48 -0500 (Thu, 23 May 2013)
| > New Revision: 6044
| > Modified:
| > cgm/trunk/util/Makefile.am
| > Log:
| > make distcheck should work on the trunk now
| > it was missing one file from distribution :(
| > Modified: cgm/trunk/util/Makefile.am
| > --- cgm/trunk/util/Makefile.am 2013-05-23 05:00:15 UTC (rev 6043)
| > +++ cgm/trunk/util/Makefile.am 2013-05-23 05:25:48 UTC (rev 6044)
| > @@ -123,6 +123,7 @@
| > DynamicDLIIterator.hpp \
| > DynamicTreeIterator.hpp \
| > ElementType.h \
| > + FacetShapeDefs.hpp \
| > GMem.hpp \
| > GeometryDefines.h \
| > GetLongOpt.hpp \
| "You will keep in perfect peace him whose mind is
| steadfast, because he trusts in you." Isaiah 26:3
| Tim Tautges Argonne National Laboratory
| (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
| phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20130523/acba042b/attachment.html>
More information about the cgma-dev
