[cgma-dev] r6026 - in cgm/trunk: . geom geom/Cholla geom/OCC	geom/facet geom/facetbool geom/virtual itaps test util
    janehu at mcs.anl.gov
    Thu Mar  7 13:28:15 CST 2013
Author: janehu
Date: 2013-03-07 13:28:15 -0600 (Thu, 07 Mar 2013)
New Revision: 6026
Added:
   cgm/trunk/geom/AutoMidsurfaceTool.cpp
   cgm/trunk/geom/AutoMidsurfaceTool.hpp
   cgm/trunk/geom/CAEntitySense.cpp
   cgm/trunk/geom/CAEntitySense.hpp
   cgm/trunk/geom/CAEntityTol.cpp
   cgm/trunk/geom/CAEntityTol.hpp
   cgm/trunk/geom/CGMHistory.cpp
   cgm/trunk/geom/CGMHistory.hpp
   cgm/trunk/geom/CubitCompat.cpp
   cgm/trunk/geom/CubitCompat.h.in
   cgm/trunk/geom/CubitCompat.hpp
   cgm/trunk/geom/GfxPreview.cpp
   cgm/trunk/geom/GfxPreview.hpp
   cgm/trunk/geom/LocalToleranceTool.cpp
   cgm/trunk/geom/LocalToleranceTool.hpp
   cgm/trunk/util/CubitFileSimModel.cpp
   cgm/trunk/util/CubitFileSimModel.hpp
   cgm/trunk/util/CubitUndo.cpp
   cgm/trunk/util/CubitUndo.hpp
Modified:
   cgm/trunk/Makefile.am
   cgm/trunk/configure.ac
   cgm/trunk/geom/Cholla/Makefile.am
   cgm/trunk/geom/Makefile.am
   cgm/trunk/geom/OCC/Makefile.am
   cgm/trunk/geom/facet/Makefile.am
   cgm/trunk/geom/facetbool/Makefile.am
   cgm/trunk/geom/virtual/Makefile.am
   cgm/trunk/itaps/Makefile.am
   cgm/trunk/test/Makefile.am
   cgm/trunk/util/Makefile.am
Log:
Changed to remove amendment directory, and put all files back to util or geom directory; Changed back to install only cgm and iGeom libraries. Passed occ, cubit and parallel make checks.
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am	2013-03-06 20:57:17 UTC (rev 6025)
+++ cgm/trunk/Makefile.am	2013-03-07 19:28:15 UTC (rev 6026)
@@ -45,13 +45,13 @@
                   geom/libcubit_geom.la \
                   util/libcubit_util.la
 else
-  CORE_CGM_LIBS = $(CGM_ll_LIB)
+  CORE_CGM_LIBS = geom/libcubit_geom.la $(CGM_ll_LIB)
 endif
-SUBDIRS = compat amendment util geom init . $(igeom_DIR) test cgm_apps
+SUBDIRS = compat util geom init . $(igeom_DIR) test cgm_apps
 # geom/testing
-libcgm_la_LIBADD = init/libcgma_init.la amendment/libcgma_amendment.la $(CORE_CGM_LIBS) $(CGM_EXT_LIBS) $(CUBIT_FILE)
+libcgm_la_LIBADD = init/libcgma_init.la $(CORE_CGM_LIBS) $(CGM_EXT_LIBS) $(CUBIT_FILE)
 libcgm_la_SOURCES =
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac	2013-03-06 20:57:17 UTC (rev 6025)
+++ cgm/trunk/configure.ac	2013-03-07 19:28:15 UTC (rev 6026)
@@ -144,7 +144,7 @@
     AC_LINK_IFELSE([AC_LANG_PROGRAM(
       [class AcisQueryEngine { public: static AcisQueryEngine* instance_; };],
       [AcisQueryEngine::instance_ = 0;])],
-      [CUBIT_LIBS="-L${CUBIT_BIN_DIR} -lcubiti$num -lcubit_geom -lcubit_util"
+      [CUBIT_LIBS="-L${CUBIT_BIN_DIR} -lcubiti$num"
        CUBIT_FILE=`expr x"$file" : x"$CUBIT_BIN_DIR/\(.*\)"`
        CUBIT_FILE="${CUBIT_BIN_DIR}/$CUBIT_FILE"
        AC_MSG_RESULT(yes)
@@ -552,7 +552,7 @@
 AC_MSG_RESULT([AM_CPPFLAGS = $AM_CPPFLAGS])
 dnl AC_OUTPUT_COMMANDS( [if test -f util/CubitUtilConfigure.h; then true; else echo "#define CUBIT_UTIL_EXPORT" > util/CubitUtilConfigure.h; fi],
 dnl                     [if test -f geom/CubitGeomConfigure.h; then true; else echo "#define CUBIT_GEOM_EXPORT" > geom/CubitGeomConfigure.h; fi] )
-AC_CONFIG_HEADERS(config.h geom/parallel/CGMmpi_config.h amendment/CubitCompat.h)
+AC_CONFIG_HEADERS(config.h geom/parallel/CGMmpi_config.h geom/CubitCompat.h)
 AC_CONFIG_HEADERS(itaps/iBase_FCDefs.h)
 AC_CONFIG_FILES(Makefile
            util/Makefile
@@ -565,7 +565,6 @@
            geom/parallel/Makefile
            init/Makefile
-           amendment/Makefile
            compat/Makefile
            cgm.make
More information about the cgma-dev
