[cgma-dev] r6020 - cgm/branches/merge-cubit14.0/geom/OCC
    janehu at mcs.anl.gov
    Fri Mar  1 12:03:07 CST 2013
Author: janehu
Date: 2013-03-01 12:03:07 -0600 (Fri, 01 Mar 2013)
New Revision: 6020
Modified:
   cgm/branches/merge-cubit14.0/geom/OCC/configure.ac.patch
Log:
trying to stick with the wiki description of patching under ros directory.
Modified: cgm/branches/merge-cubit14.0/geom/OCC/configure.ac.patch
--- cgm/branches/merge-cubit14.0/geom/OCC/configure.ac.patch	2013-03-01 17:53:24 UTC (rev 6019)
+++ cgm/branches/merge-cubit14.0/geom/OCC/configure.ac.patch	2013-03-01 18:03:07 UTC (rev 6020)
@@ -1,5 +1,5 @@
---- configure.ac	2012-11-12 04:53:15.000000000 -0600
-+++ /mnt/disk2b/jhu/OpenCASCADE6.5.4/ros/configure.ac	2013-03-01 11:13:28.000000000 -0600
+--- a/configure.ac	2012-11-12 04:53:15.000000000 -0600
++++ b/configure.ac	2013-03-01 11:13:28.000000000 -0600
 @@ -54,9 +54,7 @@
  AC_CHECK_HEADERS(iomanip.h limits.h values.h float.h)
  AC_CHECK_HEADERS(siginfo.h bits/sigset.h bstring.h sys/types.h sys/select.h)
More information about the cgma-dev
