[cgma-dev] r6010 - cgm/branches/merge-cubit14.0/geom/parallel
    janehu at mcs.anl.gov
    Mon Feb 18 12:26:18 CST 2013
Author: janehu
Date: 2013-02-18 12:26:18 -0600 (Mon, 18 Feb 2013)
New Revision: 6010
Modified:
   cgm/branches/merge-cubit14.0/geom/parallel/CABodies.cpp
   cgm/branches/merge-cubit14.0/geom/parallel/CABodies.hpp
   cgm/branches/merge-cubit14.0/geom/parallel/CGMParallelComm.cpp
   cgm/branches/merge-cubit14.0/geom/parallel/CGMReadParallel.cpp
   cgm/branches/merge-cubit14.0/geom/parallel/CGMReadParallel.hpp
   cgm/branches/merge-cubit14.0/geom/parallel/Makefile.am
   cgm/branches/merge-cubit14.0/geom/parallel/ProcData.hpp
   cgm/branches/merge-cubit14.0/geom/parallel/TDParallel.cpp
   cgm/branches/merge-cubit14.0/geom/parallel/TDParallel.hpp
Log:
Another try to checking parallel updates for cubit14.0. passed parallel make check test for cgm on occ6.5.3.
Modified: cgm/branches/merge-cubit14.0/geom/parallel/CABodies.cpp
--- cgm/branches/merge-cubit14.0/geom/parallel/CABodies.cpp	2013-02-16 16:28:56 UTC (rev 6009)
+++ cgm/branches/merge-cubit14.0/geom/parallel/CABodies.cpp	2013-02-18 18:26:18 UTC (rev 6010)
@@ -1,7 +1,6 @@
 //- Class:          CABodies
 //- Description:    Cubit Attribute for a list of bodies the entity is part of.
 //- Author: Hong-Jun Kim
-//- Checked By: Tim Tautges
 //- Version:
 #include "CABodies.hpp"
@@ -11,25 +10,18 @@
 #include "CastTo.hpp"
 #include "TDParallel.hpp"
-CubitAttrib* CABodies_creator(RefEntity* entity, CubitSimpleAttrib *p_csa)
+CubitAttrib* CABodies_creator(RefEntity* entity, const CubitSimpleAttrib& p_csa)
   CABodies *new_attrib = NULL;
-  if (NULL == p_csa)
-    new_attrib = new CABodies(entity);
-  else
-    new_attrib = new CABodies(entity, p_csa);
+  CubitSimpleAttrib csa = p_csa;
+  new_attrib = new CABodies(entity, &csa);
   return new_attrib;
 CABodies::CABodies(RefEntity* new_attrib_owner,
-                           CubitSimpleAttrib *csa_ptr)
-        : CubitAttrib(new_attrib_owner)
+		   CubitSimpleAttrib *csa_ptr)
+  : CubitAttrib(new_attrib_owner)
   assert ( csa_ptr != NULL );
   if (DEBUG_FLAG(138))
@@ -39,19 +31,44 @@
 		     (attribOwnerEntity ? attribOwnerEntity->id() : 0));
-  //initialize();
-  DLIList<int*> *i_list = csa_ptr->int_data_list();
+  std::vector<int> i_list = csa_ptr->int_data_list();
More information about the cgma-dev
