[cgma-dev] r5940 - in cgm/branches/merge-cubit14.0: . init itaps	itaps/SIDL itaps/SIDL/bserver itaps/SIDL/gserver
    janehu at mcs.anl.gov
    Fri Jan 18 12:48:08 CST 2013
Author: janehu
Date: 2013-01-18 12:48:07 -0600 (Fri, 18 Jan 2013)
New Revision: 5940
Added:
   cgm/branches/merge-cubit14.0/init/
   cgm/branches/merge-cubit14.0/init/CMakeLists.txt
   cgm/branches/merge-cubit14.0/init/InitCGMA.cpp
   cgm/branches/merge-cubit14.0/init/InitCGMA.hpp
   cgm/branches/merge-cubit14.0/init/Makefile.am
   cgm/branches/merge-cubit14.0/itaps/
   cgm/branches/merge-cubit14.0/itaps/CATag.cpp
   cgm/branches/merge-cubit14.0/itaps/CATag.hpp
   cgm/branches/merge-cubit14.0/itaps/CGMAIterator.hpp
   cgm/branches/merge-cubit14.0/itaps/CGM_iGeom.h
   cgm/branches/merge-cubit14.0/itaps/Makefile.am
   cgm/branches/merge-cubit14.0/itaps/SIDL/
   cgm/branches/merge-cubit14.0/itaps/SIDL/Cclient.make
   cgm/branches/merge-cubit14.0/itaps/SIDL/Fclient.make
   cgm/branches/merge-cubit14.0/itaps/SIDL/Makefile
   cgm/branches/merge-cubit14.0/itaps/SIDL/Makefile.in
   cgm/branches/merge-cubit14.0/itaps/SIDL/bserver/
   cgm/branches/merge-cubit14.0/itaps/SIDL/bserver/iBase_Error_Impl.cc
   cgm/branches/merge-cubit14.0/itaps/SIDL/bserver/iBase_Error_Impl.hh
   cgm/branches/merge-cubit14.0/itaps/SIDL/common.make
   cgm/branches/merge-cubit14.0/itaps/SIDL/common.make.in
   cgm/branches/merge-cubit14.0/itaps/SIDL/gserver.make
   cgm/branches/merge-cubit14.0/itaps/SIDL/gserver/
   cgm/branches/merge-cubit14.0/itaps/SIDL/gserver/iGeom_Factory_Impl.cc
   cgm/branches/merge-cubit14.0/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc
   cgm/branches/merge-cubit14.0/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.hh
   cgm/branches/merge-cubit14.0/itaps/SIDL/iBase.sidl
   cgm/branches/merge-cubit14.0/itaps/SIDL/iGeom-SIDL-Defs.inc
   cgm/branches/merge-cubit14.0/itaps/SIDL/iGeom-SIDL-Defs.inc.in
   cgm/branches/merge-cubit14.0/itaps/SIDL/iGeom.sidl
   cgm/branches/merge-cubit14.0/itaps/SIDL/iGeom_SIDL.sidl
   cgm/branches/merge-cubit14.0/itaps/SIDL/testgeom.cpp
   cgm/branches/merge-cubit14.0/itaps/brick_2.sat
   cgm/branches/merge-cubit14.0/itaps/brick_2.stp
   cgm/branches/merge-cubit14.0/itaps/chaman.cc
   cgm/branches/merge-cubit14.0/itaps/copy_attrib.cpp
   cgm/branches/merge-cubit14.0/itaps/iBase.h
   cgm/branches/merge-cubit14.0/itaps/iBase_FCDefs.h
   cgm/branches/merge-cubit14.0/itaps/iBase_FCDefs.h.in
   cgm/branches/merge-cubit14.0/itaps/iBase_f.h
   cgm/branches/merge-cubit14.0/itaps/iGeom-Defs.inc.in
   cgm/branches/merge-cubit14.0/itaps/iGeom.dox
   cgm/branches/merge-cubit14.0/itaps/iGeom.h
   cgm/branches/merge-cubit14.0/itaps/iGeomError.cc
   cgm/branches/merge-cubit14.0/itaps/iGeomError.h
   cgm/branches/merge-cubit14.0/itaps/iGeom_CGMA.cc
   cgm/branches/merge-cubit14.0/itaps/iGeom_FCDefs.h
   cgm/branches/merge-cubit14.0/itaps/iGeom_f.h
   cgm/branches/merge-cubit14.0/itaps/iGeom_private.h
   cgm/branches/merge-cubit14.0/itaps/iGeom_protos.h
   cgm/branches/merge-cubit14.0/itaps/ilc_13body.stp
   cgm/branches/merge-cubit14.0/itaps/ilc_1body.stp
   cgm/branches/merge-cubit14.0/itaps/ilc_problem_surf8.stp
   cgm/branches/merge-cubit14.0/itaps/partest.cpp
   cgm/branches/merge-cubit14.0/itaps/size.sat
   cgm/branches/merge-cubit14.0/itaps/test_edge_orient.cc
   cgm/branches/merge-cubit14.0/itaps/testgeom.cc
   cgm/branches/merge-cubit14.0/itaps/testgeom.sat
Log:
Added directory init and itaps.
Added: cgm/branches/merge-cubit14.0/init/CMakeLists.txt
--- cgm/branches/merge-cubit14.0/init/CMakeLists.txt	                        (rev 0)
+++ cgm/branches/merge-cubit14.0/init/CMakeLists.txt	2013-01-18 18:48:07 UTC (rev 5940)
@@ -0,0 +1,20 @@
+project( cgma_init )
+include_directories(
+  ${cubit_geom_SOURCE_DIR}
+  ${cubit_util_SOURCE_DIR}
+  ${cubit_geom_SOURCE_DIR}/ACIS
+  ${cubit_geom_SOURCE_DIR}/virtual
+  ${cubit_geom_SOURCE_DIR}/facet
+  ${cubit_geom_SOURCE_DIR}/cholla
+  ${cgma_init_SOURCE_DIR}
+add_library( cgma_init
+  InitCGMA.cpp
+target_link_libraries( cgma_init
+  cubit_geom
+  cubit_util
Added: cgm/branches/merge-cubit14.0/init/InitCGMA.cpp
--- cgm/branches/merge-cubit14.0/init/InitCGMA.cpp	                        (rev 0)
+++ cgm/branches/merge-cubit14.0/init/InitCGMA.cpp	2013-01-18 18:48:07 UTC (rev 5940)
@@ -0,0 +1,156 @@
+#include "InitCGMA.hpp"
+#include "CGMApp.hpp"
+#include "VirtualQueryEngine.hpp"
+#include "FacetQueryEngine.hpp"
+#include "FacetModifyEngine.hpp"
+#include "GeometryQueryTool.hpp"
+#include "GeometryModifyTool.hpp"
+#include "CubitUtil.hpp"
+#include <ctype.h>
+#ifdef CUBIT_CGM
+#include <new>
+class AcisModifyEngine
+public:
+  AcisModifyEngine();
+  static AcisModifyEngine *instance_;
More information about the cgma-dev
