[cgma-dev] r5936 - in cgm/branches/merge-cubit14.0: . test
    janehu at mcs.anl.gov
    Thu Jan 17 11:33:19 CST 2013
Author: janehu
Date: 2013-01-17 11:33:17 -0600 (Thu, 17 Jan 2013)
New Revision: 5936
Added:
   cgm/branches/merge-cubit14.0/test/
   cgm/branches/merge-cubit14.0/test/62_shaver1.brep
   cgm/branches/merge-cubit14.0/test/66_shaver3.brep
   cgm/branches/merge-cubit14.0/test/72_shaver6.brep
   cgm/branches/merge-cubit14.0/test/AngleCalc.cpp
   cgm/branches/merge-cubit14.0/test/CreateGeometry.cpp
   cgm/branches/merge-cubit14.0/test/Cylinder_1.brep
   cgm/branches/merge-cubit14.0/test/Cylinder_2.brep
   cgm/branches/merge-cubit14.0/test/GraphicsData.cpp
   cgm/branches/merge-cubit14.0/test/LeverArm.brep
   cgm/branches/merge-cubit14.0/test/Line_1.brep
   cgm/branches/merge-cubit14.0/test/Line_2.brep
   cgm/branches/merge-cubit14.0/test/Makefile.am
   cgm/branches/merge-cubit14.0/test/Makefile.am_bck
   cgm/branches/merge-cubit14.0/test/Moto.brep
   cgm/branches/merge-cubit14.0/test/Solid_2.brep
   cgm/branches/merge-cubit14.0/test/Solid_6.brep
   cgm/branches/merge-cubit14.0/test/Solid_7.brep
   cgm/branches/merge-cubit14.0/test/TestConfig.h
   cgm/branches/merge-cubit14.0/test/TestConfig.h.in
   cgm/branches/merge-cubit14.0/test/TestUtilities.cpp
   cgm/branches/merge-cubit14.0/test/TestUtilities.hpp
   cgm/branches/merge-cubit14.0/test/aftersub.occ_ref
   cgm/branches/merge-cubit14.0/test/attribute_to_file.cpp
   cgm/branches/merge-cubit14.0/test/beforesub.occ_ref
   cgm/branches/merge-cubit14.0/test/beforesub2.occ_ref
   cgm/branches/merge-cubit14.0/test/box-w-hole.brep
   cgm/branches/merge-cubit14.0/test/brick.cpp
   cgm/branches/merge-cubit14.0/test/brick.iges
   cgm/branches/merge-cubit14.0/test/cub_model.step
   cgm/branches/merge-cubit14.0/test/diffuser.iges
   cgm/branches/merge-cubit14.0/test/ex3.iges
   cgm/branches/merge-cubit14.0/test/facets.cpp
   cgm/branches/merge-cubit14.0/test/facets_README
   cgm/branches/merge-cubit14.0/test/hollow.sat
   cgm/branches/merge-cubit14.0/test/hollow_acis.cpp
   cgm/branches/merge-cubit14.0/test/holysurf.sat
   cgm/branches/merge-cubit14.0/test/huge.sat
   cgm/branches/merge-cubit14.0/test/imprint_bug.cpp
   cgm/branches/merge-cubit14.0/test/init.cpp
   cgm/branches/merge-cubit14.0/test/loft.cpp
   cgm/branches/merge-cubit14.0/test/makept.cpp
   cgm/branches/merge-cubit14.0/test/merge.sat
   cgm/branches/merge-cubit14.0/test/merge_test.cpp
   cgm/branches/merge-cubit14.0/test/model1.sat
   cgm/branches/merge-cubit14.0/test/model2.sat
   cgm/branches/merge-cubit14.0/test/model3.sat
   cgm/branches/merge-cubit14.0/test/model4.sat
   cgm/branches/merge-cubit14.0/test/model5.sat
   cgm/branches/merge-cubit14.0/test/model6.sat
   cgm/branches/merge-cubit14.0/test/model7.sat
   cgm/branches/merge-cubit14.0/test/modify.cpp
   cgm/branches/merge-cubit14.0/test/offset_curves.cpp
   cgm/branches/merge-cubit14.0/test/operation.cpp
   cgm/branches/merge-cubit14.0/test/point_project.cpp
   cgm/branches/merge-cubit14.0/test/point_project_acis.cpp
   cgm/branches/merge-cubit14.0/test/proe.stp
   cgm/branches/merge-cubit14.0/test/r_w.cpp
   cgm/branches/merge-cubit14.0/test/section.cpp
   cgm/branches/merge-cubit14.0/test/sheet.cpp
   cgm/branches/merge-cubit14.0/test/stitch.name_occ
   cgm/branches/merge-cubit14.0/test/subtract.cpp
   cgm/branches/merge-cubit14.0/test/test_occ.cpp
   cgm/branches/merge-cubit14.0/test/unite1.occ
   cgm/branches/merge-cubit14.0/test/unite4.occ
   cgm/branches/merge-cubit14.0/test/webcut.brep
   cgm/branches/merge-cubit14.0/test/webcut.cpp
Log:
Adding tests, passed make check.
Added: cgm/branches/merge-cubit14.0/test/62_shaver1.brep
--- cgm/branches/merge-cubit14.0/test/62_shaver1.brep	                        (rev 0)
+++ cgm/branches/merge-cubit14.0/test/62_shaver1.brep	2013-01-17 17:33:17 UTC (rev 5936)
@@ -0,0 +1,8034 @@
+DBRep_DrawableShape
+CASCADE Topology V1, (c) Matra-Datavision
+Locations 112
+1
+              1               0               0               0
+              0               1               0               0
+              0               0               1               0
+2  1 -1 0
+1
+              1               0              -0               0
+             -0               1               0               0
+              0               0               1           41.25
+1
+              1               0              -0               0
+             -0               1               0               0
+              0               0               1          -35.25
+1
+              1               0              -0               0
+             -0               1               0               0
+              0               0               1               2
+2  3 1 4 1 5 1 0
+1
+              1               0              -0               5
+             -0               1               0               0
+              0               0               1               0
+2  7 1 5 1 0
+1
+              1               0              -0               0
+             -0               1               0               0
+              0               0               1           38.25
+2  9 1 5 1 0
+2  3 1 5 1 0
+2  5 -1 4 -1 3 -1 0
+1
+              1               0              -0               5
+             -0               1               0               0
+              0               0               1               0
+2  13 1 5 1 0
+2  3 1 4 1 13 -1 0
+2  5 -1 13 -1 0
+2  3 1 4 1 0
+1
+              1               0              -0               0
+             -0               1               0           -6.25
+              0               0               1               0
More information about the cgma-dev
