[cgma-dev] r5871 - in cgm/trunk: . cgm_apps/examples/facetdriver	geom geom/Cholla geom/OCC geom/facetbool init itaps test util
    janehu at mcs.anl.gov
    Fri Nov 16 11:19:12 CST 2012
Author: janehu
Date: 2012-11-16 11:19:12 -0600 (Fri, 16 Nov 2012)
New Revision: 5871
Modified:
   cgm/trunk/Makefile.am
   cgm/trunk/cgm.make.in
   cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am
   cgm/trunk/configure.ac
   cgm/trunk/geom/Cholla/Makefile.am
   cgm/trunk/geom/Makefile.am
   cgm/trunk/geom/OCC/Makefile.am
   cgm/trunk/geom/facetbool/Makefile.am
   cgm/trunk/init/InitCGMA.cpp
   cgm/trunk/itaps/Makefile.am
   cgm/trunk/test/Makefile.am
   cgm/trunk/util/Makefile.am
Log:
1. Added back the 3 testcases in test directory for cgm on cubit build, they passed the test.
2. trunk is working for all 3 builds of shared or static of cgm on occ and shared build for cgm on cubit.
3. Passed all make check under trunk.
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am	2012-11-16 16:50:22 UTC (rev 5870)
+++ cgm/trunk/Makefile.am	2012-11-16 17:19:12 UTC (rev 5871)
@@ -43,15 +43,16 @@
 		  geom/Cholla/libCholla.la \
                   geom/facetbool/libcubit_facetbool.la \
                   geom/libcubit_geom.la \
-                  util/libcubit_util.la
+                  util/libcubit_util.la \
+                  amendment/libcgma_amendment.la
 else
-  CORE_CGM_LIBS = geom/libcubit_geom.la $(CGM_ll_LIB)
+  CORE_CGM_LIBS = geom/libcubit_geom.la  amendment/libcgma_amendment.la $(CGM_ll_LIB)
 endif
-SUBDIRS = compat util geom init . $(igeom_DIR) test cgm_apps
+SUBDIRS = compat amendment util geom init . $(igeom_DIR) test cgm_apps
 # geom/testing
-libcgm_la_LIBADD = init/libcgma_init.la $(CORE_CGM_LIBS) $(CGM_EXT_LIBS) $(CUBIT_FILE)
+libcgm_la_LIBADD = $(CORE_CGM_LIBS) $(CGM_EXT_LIBS) $(CUBIT_FILE)
 libcgm_la_SOURCES =
Modified: cgm/trunk/cgm.make.in
--- cgm/trunk/cgm.make.in	2012-11-16 16:50:22 UTC (rev 5870)
+++ cgm/trunk/cgm.make.in	2012-11-16 17:19:12 UTC (rev 5871)
@@ -22,6 +22,8 @@
                   -I at abs_top_builddir@/init \
                   -I at abs_top_srcdir@/geom \
                   -I at abs_top_builddir@/geom \
+                  -I at abs_top_srcdir@/amendment \
+                  -I at abs_top_builddir@/amendment \
                   -I at abs_top_srcdir@/geom/ACIS \
                   -I at abs_top_srcdir@/geom/virtual \
                   -I at abs_top_srcdir@/geom/facet \
Modified: cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am
--- cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am	2012-11-16 16:50:22 UTC (rev 5870)
+++ cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am	2012-11-16 17:19:12 UTC (rev 5871)
@@ -14,7 +14,7 @@
                -I$(top_srcdir)/geom/facetbool
 if BUILD_CGM
-  LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LIBS) $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) $(top_builddir)/geom/Cholla/libCholla.la $(top_builddir)/geom/facet/libcubit_facet.la $(top_builddir)/geom/facetbool/libcubit_facetbool.la $(top_builddir)/geom/libcubit_geom.la $(top_builddir)/util/libcubit_util.la
+  LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LIBS) $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) $(top_builddir)/geom/Cholla/libCholla.la $(top_builddir)/geom/facet/libcubit_facet.la $(top_builddir)/geom/facetbool/libcubit_facetbool.la $(top_builddir)/geom/libcubit_geom.la $(top_builddir)/util/libcubit_util.la
 else
More information about the cgma-dev
