[cgma-dev] Fwd: How to build the CGMA on Windows 7 64bit + VS2010?
    Jane Hu
    janejhu at gmail.com
    Tue Nov  6 10:17:34 CST 2012
Hello,
I need your help for the CMakeLists.txt. Can someone generate
CMakelists.txt in cgm? I am going to ask him for his file, and then we can
work on that. But I don't have clue of write it.
Thanks for your help!
Jane
---------- Forwarded message ----------
From: Zhanghong Tang <tangzhanghong98 at yahoo.com>
Date: Tue, Nov 6, 2012 at 9:57 AM
Subject: Re: [cgma-dev] How to build the CGMA on Windows 7 64bit + VS2010?
To: Jane Hu <janejhu at gmail.com>
Dear Dr. Hu,
Thank you very much for your kindly reply. From the 'CMakeLists.txt', I
can't generate the VC++ project which can build code to generate cgm.lib (
libcgm.la). Could you please update the 'CMakeLists.txt' for me to let the
CMake generate that project?
Zhanghong Tang
To: "Zhanghong Tang" <tangzhanghong98 at yahoo.com>
Date: Tuesday, November 6, 2012, 11:45 PM
Yes, you should add libcgm.la. Have you been successful?
Jane
On Mon, Nov 5, 2012 at 5:26 PM, Zhanghong Tang
<tangzhanghong98 at yahoo.com<http://mc/compose?to=tangzhanghong98@yahoo.com>
> wrote:
Dear Dr. Hu,
Thank you very much for your kindly reply. From the 'CMakeLists.txt' I can
only generate the following libs:
cgma_init.lib
cholla.lib
cubit_facet.lib
cubit_facetboolstub.lib
cubit_geom.lib
cubit_OOC.lib
cubit_util.lib
cubit_virtual.lib
compare to the libs you listed, I think the following lib should also be
added from 'CMakeLists.txt':
cgm.lib (libcgm.la)
Zhanghong Tang
<janejhu at gmail.com<http://mc/compose?to=janejhu@gmail.com>
>* wrote:
From: Jane Hu <janejhu at gmail.com <http://mc/compose?to=janejhu@gmail.com>>
Cc: cgma-dev at mcs.anl.gov <http://mc/compose?to=cgma-dev@mcs.anl.gov>
Date: Tuesday, November 6, 2012, 1:35 AM
Will adding following library work for you?
--- Makefile.am_bck     2012-11-05 11:24:26.000000000 -0600
+++ Makefile.am 2012-11-05 11:28:50.000000000 -0600
@@ -27,7 +27,11 @@
 check_PROGRAMS = $(TESTS)
-LDADD = ../libcgm.la ../geom/libcubit_geom.la ../util/libcubit_util.la
libcgm_test.la ../geom/virtual/libcubit_virtual.la ../geom/facet/
libcubit_facet.la $(CGM_EXT_LIBS) $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
+  LDADD = ../libcgm.la ../geom/libcubit_geom.la ../init/libcgma_init.la../util/
libcubit_util.la libcgm_test.la
../geom/virtual/libcubit_virtual.la../geom/facet/
 noinst_LTLIBRARIES = libcgm_test.la
 libcgm_test_la_SOURCES = TestUtilities.hpp \
Jane
On Mon, Nov 5, 2012 at 11:10 AM, Zhanghong Tang
> wrote:
Dear Dr. Hu,
Thank you very much for your sample code. I noticed that in the main
function you also have the following line:
  CubitStatus status = InitCGMA::initialize_cgma("OCC");
which will pop up error on my machine. So I still missed something.
Is there anyone who have successfully configured CGMA by CMake in Windows?
Zhanghong Tang
Cc: "Iulian Grindeanu"
<iulian at mcs.anl.gov<http://mc/compose?to=iulian@mcs.anl.gov>>,
Date: Tuesday, November 6, 2012, 12:57 AM
Sorry, I forgot the attachment.
On Mon, Nov 5, 2012 at 10:49 AM, Jane Hu
> wrote:
Hello  Zhanghong,
I understand that at some point, you wanted a simple test for boolean
operation for a box and a sphere.
I work on Linux machine, and am currently running on cgm-occ code from our
trunk location. I just built a small tests of size 1 block and a radius=0.7
sphere and got results for intersection and subtractions stored in
intersection.brep and box-sphere.brep(for box subtracts sphere) and
sphere-box.brep( sphere subtracts box).
I hope you good luck in your build (sorry I can't be much help on your
cmake build,) and I hope the testcase and result files can help you save
some time testing.
Jane
On Mon, Nov 5, 2012 at 9:07 AM, Zhanghong Tang
> wrote:
Dear Dr. Grindeanu,
Thank you very much for your kindly reply. I attached the VS2010 project
created by CMake (64bit.zip). Except that I provided the include and
library folders of OOC when configure the CMake, I used all default values
to generate VS2010 project.
The libraries can be built successfully, however, it failed after I created
a simple test project "cgmatest', this project and source code are also
attached ('cgmatest.zip').
Zhanghong Tang
--- On *Mon, 11/5/12, Iulian Grindeanu
Date: Monday, November 5, 2012, 10:40 PM
Hello,
How did you configure? Even if you use cmake, at some point you need to
have a configuration step.
You can see what we build every night here:
http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
Those are all built on a Linux compute node, ubuntu 10.04, 64-bit.
The configuration closest to yours' is probably cgm-occ or cgm-occ-sta.
These are built on merge cubit 12.2 branch, with occ version 6.5.3
http://gnep.mcs.anl.gov:8010/builders/cgm-occ
or
http://gnep.mcs.anl.gov:8010/builders/cgm-occ-sta
If you send your config.log file (or equivalent?) , we may have some clues
of what is not working.
Best Regards,
Iulian
Dear all,
I have successfully built the project 'cubit_OOC' after I used the version
12.2 from here:
https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/Version12.2/
However, after I built a simple example "\test\operation.cpp" and run it,
the following error displayed:
ERROR: Invalid or unsupported engine: 'OCC'
Is there anything I missed?
Zhanghong Tang
--- On *Sun, 11/4/12, Iulian Grindeanu
Date: Sunday, November 4, 2012, 12:51 AM
 Hello,
It would be good if you can make it work.
How did you configure ? Using ccmake or autotools in cygwin?
You should configure with-occ OR with-cubit, if you have cubit.
It seems that you installed occ, so configure ONLY with-occ.
I will be out of email until Monday
Iulian
Dear Dr. Grindeanu,
Thank you very much for pointing out my problem. I thought that the CGMA
can work without any other package.
Now I have installed Open CASCADE Technology 6.5.3 and rebuild the CGMA
project (reset the path by CMake and create the VS2010 projects), the
following error displayed when build the cubit_OCC project:
1>------ Build started: Project: ZERO_CHECK, Configuration: Debug x64 ------
1>Build started 2012/11/3 23:41:53.
1>InitializeBuildStatus:
1>  Creating "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild" because
"AlwaysCreate" was specified.
1>FinalizeBuildStatus:
1>  Deleting file "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild".
1>  Touching "x64\Debug\ZERO_CHECK\ZERO_CHECK.lastbuildstate".
1>
1>Build succeeded.
1>
1>Time Elapsed 00:00:00.06
2>------ Build started: Project: cubit_OCC, Configuration: Debug x64 ------
2>Build started 2012/11/3 23:41:53.
2>InitializeBuildStatus:
2>  Touching "cubit_OCC.dir\Debug\cubit_OCC.unsuccessfulbuild".
2>CustomBuild:
2>  All outputs are up-to-date.
2>ClCompile:
2>  OCCModifyEngine.cpp
2>E:\cgma-12.2.0b1\util\CubitMessage.hpp(400): warning C4138: '*/' found
outside of comment
2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(259): warning C4138: '*/'
found outside of comment
2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(260): warning C4138: '*/'
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(715): error C2440:
'<function-style-cast>' : cannot convert from
'Handle_Geom_RectangularTrimmedSurface' to 'BRepBuilderAPI_MakeFace'
2>          No constructor could take the source type, or constructor
overload resolution was ambiguous
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(725): error C2440:
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(744): error C2665:
'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace' : none of the 23
overloads could convert all the argument types
2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(104):
could be 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Pln
&,const Standard_Real,const Standard_Real,const Standard_Real,const
Standard_Real)'
2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(106):
or       'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const
gp_Cylinder &,const Standard_Real,const Standard_Real,const
Standard_Real,const Standard_Real)'
2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(108):
or       'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Cone
Standard_Real)'
2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(110):
or       'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Sphere
Standard_Real)'
2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(112):
or       'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Torus
Standard_Real)'
2>          while trying to match the argument list
'(Handle_Geom_BezierSurface, double, double, double, double)'
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(2267): warning C4800:
'Standard_Boolean' : forcing value to bool 'true' or 'false' (performance
warning)
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(7913): error C2440:
2>
2>Build FAILED.
2>
2>Time Elapsed 00:00:01.52
3>------ Build started: Project: ALL_BUILD, Configuration: Debug x64 ------
3>Build started 2012/11/3 23:41:54.
3>InitializeBuildStatus:
3>  Creating "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild" because
3>CustomBuild:
3>  Build all projects
3>FinalizeBuildStatus:
3>  Deleting file "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild".
3>  Touching "x64\Debug\ALL_BUILD\ALL_BUILD.lastbuildstate".
3>
3>Build succeeded.
3>
3>Time Elapsed 00:00:02.02
4>------ Skipped Build: Project: INSTALL, Configuration: Debug x64 ------
4>Project not selected to build for this solution configuration
========== Build: 2 succeeded, 1 failed, 7 up-to-date, 1 skipped ==========
Could you please take a look at it for me?
Zhanghong Tang
--- On *Sat, 11/3/12, Iulian Grindeanu
Cc: "CGMA Development"
<cgma-dev at mcs.anl.gov<http://mc/compose?to=cgma-dev@mcs.anl.gov>
Date: Saturday, November 3, 2012, 10:30 PM
Dear Dr. Grindeanu,
Thank you very much for your kindly reply. With the help of CMake I have
successfully build the libraries. There are 7 libs generated:
cgma_init.lib
cholla.lib
cubit_facet.lib
cubit_geom.lib
cubit_util.lib
cubit_virtual.lib
Hello,
So I assume you are on the main branch.
You can't use CGM without a geometry engine. Did you read my previous
e-mail?
You will need to configure with OCC or Cubit.
Sorry, I can't be of more help.
Iulian
I tried to build a simple test "brick.cpp", however, there are some errors
when run the example:
Facet-based geometry modification is a beta capability.
ERROR: This capability is currently disabled.
To enable this capability, issue the command 'set developer commands on'.
ERROR: In GeometryModifyTool::brick
       Problem creating a brick.
Assertion failed: brick != 0, file ..\test\brick.cpp, line 42
I would like to do a simple test:
1) build a box and a sphere with both center at (0,0,0) and size 1;
2) do boolean operations such as intersection between the box and sphere;
3) output the result to an OFF file.
Could anyone give me such a simple example?
Zhanghong Tang
--- On *Fri, 11/2/12, Iulian Grindeanu
Date: Friday, November 2, 2012, 11:21 PM
Hello,
I don't know if anybody tried building on Windows, maybe Jane or Tim know.
You have to configure with a geometric engine. If you don't have Cubit for
your platform, you will need to configure with OCC
It seems that you use cygwin.  I know that OCC can be build on Windows, on
VS 2010.
(http://www.opencascade.org/getocc/require/)
You then can try configuring on cygwin with occ. And then look at Makefiles
generated to see what would be needed for projects in VS. Or is there a
cmake-based build? I think that would be easier to port to Windows.
Iulian
Dear all,
I am trying to build the CGMA on Windows 7 64bit + VS2010. I have attached
the project. However, there are hundreds of errors such as:
2>CGMAD.lib(DAG.obj) : error LNK2019: unresolved external symbol "public:
__cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)"
(??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ) referenced in function "public:
enum CubitStatus __cdecl DAG::get_children_at_level(class DLIList<class
ModelEntity *> &,int,class DLIList<class ModelEntity *> &)"
(?get_children_at_level at DAG@@QEAA?AW4CubitStatus@
@AEAV?$DLIList at PEAVModelEntity@@@@H0 at Z)
2>CGMAD.lib(CAActuateSet.obj) : error LNK2001: unresolved external symbol
"public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity
*>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
2>CGMAD.lib(PartitionTool.obj) : error LNK2001: unresolved external symbol
2>CGMAD.lib(CompositeTool.obj) : error LNK2001: unresolved external symbol
2>CGMAD.lib(TopologyEntity.obj) : error LNK2001: unresolved external symbol
Could anyone help me to take a look at it and give me some hints on how to
setup the project or modify some code to successfully build the project?
Zhanghong Tang
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
(Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
(Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
(Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121106/6f210469/attachment-0001.html>
More information about the cgma-dev
