[cgma-dev] How to build the CGMA on Windows 7 64bit + VS2010?
Zhanghong Tang
tangzhanghong98 at yahoo.com
Mon Nov 5 09:07:00 CST 2012
Dear Dr. Grindeanu,
Thank you very much for your kindly reply. I attached the VS2010 project created by CMake (64bit.zip). Except that I provided the include and library folders of OOC when configure the CMake, I used all default values to generate VS2010 project.
The libraries can be built successfully, however, it failed after I created a simple test project "cgmatest', this project and source code are also attached ('cgmatest.zip').
Zhanghong Tang
--- On Mon, 11/5/12, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
Subject: Re: [cgma-dev] How to build the CGMA on Windows 7 64bit + VS2010?
To: "Zhanghong Tang" <tangzhanghong98 at yahoo.com>
Cc: cgma-dev at mcs.anl.gov
Date: Monday, November 5, 2012, 10:40 PM
#yiv776925597 p {margin:0;}Hello,
How did you configure? Even if you use cmake, at some point you need to have a configuration step.
You can see what we build every night here:
http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
Those are all built on a Linux compute node, ubuntu 10.04, 64-bit.
The configuration closest to yours' is probably cgm-occ or cgm-occ-sta.
These are built on merge cubit 12.2 branch, with occ version 6.5.3
http://gnep.mcs.anl.gov:8010/builders/cgm-occ
or
http://gnep.mcs.anl.gov:8010/builders/cgm-occ-sta
If you send your config.log file (or equivalent?) , we may have some clues of what is not working.
Best Regards,
Iulian
Dear all,
I have successfully built the project 'cubit_OOC' after I used the version 12.2 from here:
https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/Version12.2/
However, after I built a simple example "\test\operation.cpp" and run it, the following error displayed:
ERROR: Invalid or unsupported engine: 'OCC'
Is there anything I missed?
Zhanghong Tang
Date: Sunday, November 4, 2012, 12:51 AM
It would be good if you can make it work.
How did you configure ? Using ccmake or autotools in cygwin?
You should configure with-occ OR with-cubit, if you have cubit.
It seems that you installed occ, so configure ONLY with-occ.
I will be out of email until Monday
Iulian
Dear Dr. Grindeanu,
Thank you very much for pointing out my problem. I thought that the CGMA can work without any other package.
Now I have installed Open CASCADE Technology 6.5.3 and rebuild the CGMA project (reset the path by CMake and create the VS2010 projects), the
following error displayed when build the cubit_OCC project:
1>------ Build started: Project: ZERO_CHECK, Configuration: Debug x64 ------
1>Build started 2012/11/3 23:41:53.
1>InitializeBuildStatus:
1> Creating "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild" because "AlwaysCreate" was specified.
1>FinalizeBuildStatus:
1> Deleting file "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild".
1> Touching "x64\Debug\ZERO_CHECK\ZERO_CHECK.lastbuildstate".
1>
1>Build succeeded.
1>
1>Time Elapsed
00:00:00.06
2>------ Build started: Project: cubit_OCC, Configuration: Debug x64 ------
2>Build started 2012/11/3 23:41:53.
2>InitializeBuildStatus:
2> Touching "cubit_OCC.dir\Debug\cubit_OCC.unsuccessfulbuild".
2>CustomBuild:
2> All outputs are up-to-date.
2>ClCompile:
2> OCCModifyEngine.cpp
2>E:\cgma-12.2.0b1\util\CubitMessage.hpp(400): warning C4138: '*/' found outside of comment
2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(259): warning C4138: '*/' found outside of comment
2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(260): warning C4138: '*/' found outside of comment
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(715): error C2440: '<function-style-cast>' : cannot convert from 'Handle_Geom_RectangularTrimmedSurface' to 'BRepBuilderAPI_MakeFace'
2> No constructor could take the source type, or
constructor overload resolution was ambiguous
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(725): error C2440: '<function-style-cast>' : cannot convert from 'Handle_Geom_RectangularTrimmedSurface' to 'BRepBuilderAPI_MakeFace'
2> No constructor could take the source type, or constructor overload resolution was ambiguous
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(744): error C2665: 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace' : none of the 23 overloads could convert all the argument types
2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(104): could be 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Pln &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2>
C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(106): or 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Cylinder &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(108): or 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Cone &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(110): or 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Sphere &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2>
C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(112): or 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Torus &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2> while trying to match the argument list '(Handle_Geom_BezierSurface, double, double, double, double)'
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(2267): warning C4800: 'Standard_Boolean' : forcing value to bool 'true' or 'false' (performance warning)
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(7913): error C2440: '<function-style-cast>' : cannot convert from 'Handle_Geom_RectangularTrimmedSurface' to 'BRepBuilderAPI_MakeFace'
2>
2>Build FAILED.
2>
2>Time
Elapsed 00:00:01.52
3>------ Build started: Project: ALL_BUILD, Configuration: Debug x64 ------
3>Build started 2012/11/3 23:41:54.
3>InitializeBuildStatus:
3> Creating "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild" because "AlwaysCreate" was specified.
3>CustomBuild:
3> Build all projects
3>FinalizeBuildStatus:
3> Deleting file "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild".
3> Touching "x64\Debug\ALL_BUILD\ALL_BUILD.lastbuildstate".
3>
3>Build succeeded.
3>
3>Time Elapsed 00:00:02.02
4>------ Skipped Build: Project: INSTALL, Configuration: Debug x64 ------
4>Project not selected to build for this solution configuration
========== Build: 2 succeeded, 1 failed, 7 up-to-date, 1 skipped ==========
Could you please take a look at it for me?
Zhanghong Tang
--- On Sat, 11/3/12, Iulian
Cc: "CGMA Development" <cgma-dev at mcs.anl.gov>
Date: Saturday, November 3, 2012, 10:30 PM
Dear Dr. Grindeanu,
Thank you very much for your kindly reply. With the
help of CMake I have successfully build the libraries. There are 7 libs generated:
cgma_init.lib
cholla.lib
cubit_facet.lib
cubit_facetboolstub.lib
cubit_geom.lib
cubit_util.lib
cubit_virtual.lib
Hello,
So I assume you are on the main branch.
You can't use CGM without a geometry engine. Did you read my previous e-mail?
You will need to configure with OCC or Cubit.
Sorry, I can't be of more help.
Iulian
I tried to build a simple test "brick.cpp", however, there are some errors when run the example:
Facet-based geometry modification is a beta capability.
ERROR: This capability is currently disabled.
To enable this capability, issue the command 'set developer
commands on'.
ERROR: In GeometryModifyTool::brick
Problem creating a brick.
Assertion failed: brick != 0, file ..\test\brick.cpp, line 42
I would like to do a simple test:
1) build a box and a sphere with both center at (0,0,0) and size
1;
2) do boolean operations such as intersection between the box and sphere;
3) output the result to an OFF file.
Could anyone give me such a simple example?
Zhanghong Tang
Date: Friday, November 2, 2012, 11:21 PM
I don't know if anybody tried building on Windows, maybe Jane or Tim know.
You have to configure
with a geometric engine. If you don't have Cubit for your platform, you will need to configure with OCC
It seems that you use cygwin. I know that OCC can be build on Windows, on VS 2010.
(http://www.opencascade.org/getocc/require/)
You then can try configuring on cygwin with occ. And then look at Makefiles generated to see what would be needed for projects in VS. Or is there a cmake-based build? I think that would be easier to port to Windows.
Iulian
Dear all,
I am trying to build the CGMA on Windows 7 64bit + VS2010. I have attached the project. However, there are hundreds of errors such as:
2>CGMAD.lib(DAG.obj) : error LNK2019: unresolved external symbol "public: __cdecl
DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ) referenced in function "public: enum CubitStatus __cdecl DAG::get_children_at_level(class DLIList<class ModelEntity *> &,int,class DLIList<class ModelEntity *> &)" (?get_children_at_level at DAG@@QEAA?AW4CubitStatus@@AEAV?$DLIList at PEAVModelEntity@@@@H0 at Z)
2>CGMAD.lib(CAActuateSet.obj) : error LNK2001: unresolved external symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)"
2>CGMAD.lib(PartitionTool.obj) : error LNK2001: unresolved external symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
2>CGMAD.lib(CompositeTool.obj) : error LNK2001: unresolved external symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
2>CGMAD.lib(TopologyEntity.obj) : error LNK2001: unresolved external symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
Could anyone help me to take a look at it and give me some hints on how to setup the project or modify some code to successfully build the project?
Zhanghong
Tang
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121105/34299553/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121105/34299553/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121105/34299553/attachment-0003.obj>
More information about the cgma-dev
