[cgma-dev] r5836 - cgm/trunk
    janehu at mcs.anl.gov
    Fri Oct 26 12:29:24 CDT 2012
Author: janehu
Date: 2012-10-26 12:29:24 -0500 (Fri, 26 Oct 2012)
New Revision: 5836
Modified:
   cgm/trunk/configure.ac
Log:
Remove determination phrases for CUBIT_12, since it's a cubit13 version.
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac	2012-10-26 16:59:33 UTC (rev 5835)
+++ cgm/trunk/configure.ac	2012-10-26 17:29:24 UTC (rev 5836)
@@ -162,53 +162,6 @@
     [CUBIT_CAT_DEFINES=-DACIS_TWEAK_TOOL_CAT; AC_MSG_RESULT([yes])],
     [CUBIT_CAT_DEFINES=; AC_MSG_RESULT([no])])
-  # Test for Cubit 13.1 and later import_solid_model
-  AC_MSG_CHECKING([For Cubit 13 minor revision API])
-  # Set to 1 if it looks like Cubit 13.1,
-  # otherwise set to zero
-  CUBIT_MINOR_API=1
-  if test $CUBIT_MINOR_API = 0; then
-    AC_LINK_IFELSE([AC_LANG_PROGRAM(
-      [enum Model_File_Type { MFT_NOT_DEFINED = 0 };
-       struct ModelImportOptions;
-       class RefEntity;
-       class CubitString;
-       template <typename T> class DLIList;
-       class GeometryQueryTool { public:
-         void import_solid_model( const char*, Model_File_Type,
-                ModelImportOptions&, DLIList<RefEntity*>* );
-         void export_solid_model( DLIList<RefEntity*>&, const char*,
-                Model_File_Type, int&, CubitString const&, ModelExportOptions );
-      [GeometryQueryTool* ptr = 0;
-       ModelImportOptions* opt = 0;
-       DLIList<RefEntity*>* list = 0;
-       CubitString* str = 0;
-       int i;
-       ptr->import_solid_model( 0, MFT_NOT_DEFINED, *opt, 0 );
-       ptr->export_solid_model( *list, 0, MFT_NOT_DEFINED, i, *str, 0 );])],
-      [CUBIT_MINOR_API=2])
-  fi
-      [struct ModelImportOptions;
-       class RefEntity;
-         void import_solid_model( const char*, const char*,
-       ptr->import_solid_model( 0, 0, *opt, 0 );])],
-      [CUBIT_MINOR_API=1])
-  fi
More information about the cgma-dev
