[cgma-dev] buildbot failure in cgm-occ: failed test
    Jane Hu
    janejhu at gmail.com
    Wed Oct 24 10:08:08 CDT 2012
This still looks like the CUBIT_12 flag is not set correctly. I am going to
add it in merge-cubit12.2 branch.
Jane
On Wed, Oct 24, 2012 at 12:43 AM, <cgma-dev at mcs.anl.gov> wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-occ<http://gnep.mcs.anl.gov:8010/builders/cgm-occ>build
> #984 <http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/984> *Results:*failed
> test *Buildslave:*gnep *Revision:*None *Reason:*The Nightly scheduler
> named 'cgm-occ-ser-nightly' triggered this build Log Excerpt
> Making check in .
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-occ/build'
> make[2]: Nothing to be done for `check-am'.
>  ...Making check in itaps
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/itaps'
> make  check-recursive
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/itaps'
> Making check in .
> make[4]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/itaps'
> make  chaman test_edge_orient   testgeom_occ copy_attrib
> make[5]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/itaps'
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init     -Wall -pipe -pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o chaman.o chaman.cc
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init     -Wall -pipe -pedantic -O2 -DNDEBUG -MT test_edge_orient.o -MD -MP -MF .deps/test_edge_orient.Tpo -c -o test_edge_orient.o test_edge_orient.cc
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init   -DFORCE_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT testgeom_occ-testgeom.o -MD -MP -MF .deps/testgeom_occ-testgeom.Tpo -c -o testgeom_occ-testgeom.o `test -f 'testgeom.cc' || echo './'`testgeom.cc
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init     -Wall -pipe -pedantic -O2 -DNDEBUG -MT copy_attrib.o -MD -MP -MF .deps/copy_attrib.Tpo -c -o copy_attrib.o copy_attrib.cpp
> mv -f .deps/chaman.Tpo .deps/chaman.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o chaman chaman.o libiGeom.la -lTKernel -lm
> mv -f .deps/copy_attrib.Tpo .deps/copy_attrib.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o copy_attrib copy_attrib.o libiGeom.la -lTKernel -lm
> mv -f .deps/test_edge_orient.Tpo .deps/test_edge_orient.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o test_edge_orient test_edge_orient.o libiGeom.la -lTKernel -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/chaman chaman.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occser/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/copy_attrib copy_attrib.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occser/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/test_edge_orient test_edge_orient.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occser/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
> ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::reflect(BasicTopologyEntity*, CubitVector const&, bool, bool)'
> ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::reflect(DLIList**, CubitVector const&, bool)'
> ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::scale(BasicTopologyEntity*, CubitVector const&, bool, bool)'
> ./.libs/libiGeom.so: undefined reference to `RefEdge::get_graphics(GMem&, double)'
> ./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::scale(Body*, CubitVector const&, bool, bool)'
> ./.libs/libiGeom.so: undefined reference to `GeometryModifyTool::intersect(Body*, DLIList**&, DLIList**&, bool)'
> ./.libs/libiGeom.so: undefined reference to `GeometryModifyTool::sweep_rotational(DLIList**&, CubitVector const&, CubitVector const&, double, int, double, int, bool, bool, bool)'
> collect2: ld returned 1 exit status
>  ...make[5]: *** Waiting for unfinished jobs....
>  ..../.libs/libiGeom.so: undefined reference to `GeometryQueryTool::reflect(BasicTopologyEntity*, CubitVector const&, bool, bool)'
>  ...mv -f .deps/testgeom_occ-testgeom.Tpo .deps/testgeom_occ-testgeom.Po
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121024/aee26d2e/attachment.html>
More information about the cgma-dev
