[cgma-dev] r5798 - in cgm/trunk: cgm_apps/examples/facetdriver test
    janehu at mcs.anl.gov
    Mon Oct 15 11:49:47 CDT 2012
Author: janehu
Date: 2012-10-15 11:49:47 -0500 (Mon, 15 Oct 2012)
New Revision: 5798
Modified:
   cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am
   cgm/trunk/test/Makefile.am
Log:
Should satisfy the 'make check' before 'make install' request.
Modified: cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am
--- cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am	2012-10-15 16:16:32 UTC (rev 5797)
+++ cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am	2012-10-15 16:49:47 UTC (rev 5798)
@@ -13,5 +13,4 @@
                -I$(top_srcdir)/geom/facet \
                -I$(top_srcdir)/geom/facetbool
-LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LIBS)
-AM_LDFLAGS += $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)  -lcubit_geom -lcubit_util -lcubit_facetbool -lcubit_facet -lCholla -lcubit_virtual -ldl
+LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LIBS) $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2012-10-15 16:16:32 UTC (rev 5797)
+++ cgm/trunk/test/Makefile.am	2012-10-15 16:49:47 UTC (rev 5798)
@@ -27,8 +27,7 @@
 check_PROGRAMS = $(TESTS)
-LDADD = ../libcgm.la libcgm_test.la $(CGM_EXT_LIBS)
-AM_LDFLAGS += $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) -lcubit_geom -lcubit_util -lcubit_virtual -lcubit_facet
+LDADD = ../libcgm.la libcgm_test.la $(CGM_EXT_LIBS) $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
 noinst_LTLIBRARIES = libcgm_test.la
 libcgm_test_la_SOURCES = TestUtilities.hpp \
More information about the cgma-dev
