[cgma-dev] r5792 - cgm/trunk/itaps
    iulian at mcs.anl.gov
    Sat Oct 13 18:52:56 CDT 2012
Author: iulian
Date: 2012-10-13 18:52:56 -0500 (Sat, 13 Oct 2012)
New Revision: 5792
Added:
   cgm/trunk/itaps/brick_2.sat
Log:
this file was missing somehow, from repository
needed by ACIS/cubit tests
Added: cgm/trunk/itaps/brick_2.sat
--- cgm/trunk/itaps/brick_2.sat	                        (rev 0)
+++ cgm/trunk/itaps/brick_2.sat	2012-10-13 23:52:56 UTC (rev 5792)
@@ -0,0 +1,157 @@
+1900 0 1 0
+10 Cubit 12.2 17 ACIS 19.0.2 Linux 24 Sat Oct 13 18:50:18 2012
+1 9.9999999999999995e-07 1e-10
+body $1 -1 -1 $-1 $2 $-1 $3 T -1 -1 -1 1 1 1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $4 $-1 $0 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+lump $5 -1 -1 $-1 $-1 $6 $0 T -1 -1 -1 1 1 1 #
+transform $-1 -1 1 0 0 0 1 0 0 0 1 0 0 0 1 no_rotate no_reflect no_shear #
+simple-snl-attrib $-1 -1 $7 $1 $0 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 3 @11 ENTITY_NAME @1 1 @1 _ 0 0 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $8 $-1 $2 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+shell $-1 -1 -1 $-1 $-1 $-1 $9 $-1 $2 T -1 -1 -1 1 1 1 #
+string_attrib-name_attrib-gen-attrib $-1 -1 $10 $4 $0 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @15 ATTRIB_XACIS_ID @2 55 #
+string_attrib-name_attrib-gen-attrib $-1 -1 $11 $5 $2 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @15 ATTRIB_XACIS_ID @2 55 #
+face $12 -1 -1 $-1 $13 $14 $6 $-1 $15 forward single T -1 -1 1 1 1 1 F #
+string_attrib-name_attrib-gen-attrib $-1 -1 $16 $7 $0 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @23 ATTRIB_XSTEP_PRODUCT_ID @1 1 #
+string_attrib-name_attrib-gen-attrib $-1 -1 $17 $8 $2 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @23 ATTRIB_XSTEP_PRODUCT_ID @1 1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $18 $-1 $9 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+face $19 -1 -1 $-1 $20 $21 $6 $-1 $22 reversed single T -1 -1 -1 1 1 -1 F #
+loop $23 -1 -1 $-1 $-1 $24 $9 T -1 -1 1 1 1 1 unknown #
+plane-surface $-1 -1 -1 $-1 0 0 1 0 0 1 1 -0 0 forward_v I I I I #
+string_attrib-name_attrib-gen-attrib $-1 -1 $-1 $10 $0 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @17 ATTRIB_XACIS_NAME @1 1 #
+string_attrib-name_attrib-gen-attrib $-1 -1 $-1 $11 $2 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @17 ATTRIB_XACIS_NAME @1 1 #
+string_attrib-name_attrib-gen-attrib $-1 -1 $-1 $12 $9 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @15 ATTRIB_XACIS_ID @2 75 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $25 $-1 $13 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+face $26 -1 -1 $-1 $27 $28 $6 $-1 $29 reversed single T -1 -1 -1 1 -1 1 F #
+loop $30 -1 -1 $-1 $-1 $31 $13 T -1 -1 -1 1 1 -1 periphery $22 T #
+plane-surface $-1 -1 -1 $-1 0 0 -1 0 0 1 1 -0 0 forward_v I I I I #
+string_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $14 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @15 ATTRIB_XACIS_ID @8 -5045104 #
+coedge $-1 -1 -1 $-1 $32 $33 $34 $35 forward $14 $-1 #
+string_attrib-name_attrib-gen-attrib $-1 -1 $-1 $19 $13 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @15 ATTRIB_XACIS_ID @2 76 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $36 $-1 $20 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+face $37 -1 -1 $-1 $38 $39 $6 $-1 $40 reversed single T -1 -1 -1 -1 1 1 F #
+loop $41 -1 -1 $-1 $-1 $42 $20 T -1 -1 -1 1 -1 1 unknown #
+plane-surface $-1 -1 -1 $-1 0 -1 0 0 1 0 1 0 -0 forward_v I I I I #
+string_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $21 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @15 ATTRIB_XACIS_ID @8 -5045104 #
+coedge $-1 -1 -1 $-1 $43 $44 $45 $46 forward $21 $-1 #
+coedge $-1 -1 -1 $-1 $47 $24 $48 $49 forward $14 $-1 #
+coedge $-1 -1 -1 $-1 $24 $47 $50 $51 forward $14 $-1 #
+coedge $-1 -1 -1 $-1 $52 $53 $24 $35 reversed $54 $-1 #
+edge $55 -1 -1 $-1 $56 -1 $57 1 $24 $58 forward @7 unknown T 1 -1 1 1 1 1 #
+string_attrib-name_attrib-gen-attrib $-1 -1 $-1 $26 $20 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @15 ATTRIB_XACIS_ID @2 77 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $59 $-1 $27 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+face $60 -1 -1 $-1 $61 $62 $6 $-1 $63 reversed single T -1 1 -1 1 1 1 F #
+loop $64 -1 -1 $-1 $-1 $65 $27 T -1 -1 -1 -1 1 1 unknown #
+plane-surface $-1 -1 -1 $-1 -1 0 0 1 0 0 0 1 -0 forward_v I I I I #
+string_attrib-name_attrib-gen-attrib $-1 -1 $-1 $-1 $28 2 1 2 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @15 ATTRIB_XACIS_ID @8 -5045104 #
+coedge $-1 -1 -1 $-1 $66 $50 $67 $68 forward $28 $-1 #
More information about the cgma-dev
