[cgma-dev] r5772 - cgm/branches/merge-cubit12.2
    janehu at mcs.anl.gov
    Tue Oct  9 12:08:15 CDT 2012
Author: janehu
Date: 2012-10-09 12:08:15 -0500 (Tue, 09 Oct 2012)
New Revision: 5772
Added:
   cgm/branches/merge-cubit12.2/CMakeLists.txt
   cgm/branches/merge-cubit12.2/KNOWN_ISSUES
   cgm/branches/merge-cubit12.2/LICENSE.CGM
   cgm/branches/merge-cubit12.2/Makefile.am
   cgm/branches/merge-cubit12.2/README.CGM
   cgm/branches/merge-cubit12.2/README.CONFIGURE
   cgm/branches/merge-cubit12.2/README.OCC
   cgm/branches/merge-cubit12.2/README.OpenCascade
   cgm/branches/merge-cubit12.2/cgm.make.in
   cgm/branches/merge-cubit12.2/configure.ac
Log:
Move trunk cgm to here, and then move merge-cubit13.1 to trunk.
Added: cgm/branches/merge-cubit12.2/CMakeLists.txt
--- cgm/branches/merge-cubit12.2/CMakeLists.txt	                        (rev 0)
+++ cgm/branches/merge-cubit12.2/CMakeLists.txt	2012-10-09 17:08:15 UTC (rev 5772)
@@ -0,0 +1,5 @@
+# do util and geom and test subdirs
+SUBDIRS( util geom test init )
Added: cgm/branches/merge-cubit12.2/KNOWN_ISSUES
--- cgm/branches/merge-cubit12.2/KNOWN_ISSUES	                        (rev 0)
+++ cgm/branches/merge-cubit12.2/KNOWN_ISSUES	2012-10-09 17:08:15 UTC (rev 5772)
@@ -0,0 +1,27 @@
+This is a list of the known issues with CGM on OCC.For more details please see
+the online ticket system at the MOAB website:
+    https://trac.mcs.anl.gov/projects/ITAPS/wiki
+ID   Severity  Summary/Details
+175 critical  imprint special cases fail with crash.
+176 minor     CGM memory leak
+178 major     Unite function doesn't unite smoothly connected surfaces.
+179 major     mcnp2cad test suite lat1-7 not working, needs debugging.
+180 major     There are lots new functions or added functions to exsisting
+              functions requirements to port OCC to cubit12.
+181 minor     Lack of good cases for testing purpose.
+182 minor     Dirty geometry/imported geometry is not tested for read/repair yet
+183 minor     Don't have proper tool to visualize the TopoDS_Shapes, debugging
+           process is long preparing for graphics to understand the issue
+185 major     mcnp2cad/tests/INP-torus test case fails on imprinting 2 spline
+              surfaces.
Added: cgm/branches/merge-cubit12.2/LICENSE.CGM
--- cgm/branches/merge-cubit12.2/LICENSE.CGM	                        (rev 0)
+++ cgm/branches/merge-cubit12.2/LICENSE.CGM	2012-10-09 17:08:15 UTC (rev 5772)
@@ -0,0 +1,21 @@
+CGM, the Common Geometry Module, is a code library which provides
+geometry functionality used for mesh generation and other applications.
More information about the cgma-dev
