[cgma-dev] r5765 - cgm/branches/merge-cubit13.1/geom/OCC
janehu at mcs.anl.gov
Thu Oct 4 11:01:47 CDT 2012
Author: janehu
Date: 2012-10-04 11:01:47 -0500 (Thu, 04 Oct 2012)
New Revision: 5765
Modified:
cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.cpp
cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.hpp
cgm/branches/merge-cubit13.1/geom/OCC/OCCQueryEngine.cpp
Log:
Fixed lat4,holes problem by adding preventive check for curve's looplist, and remove stale pointers. Passed make check in related directories in cgm. cgm_apps/examples/facetdriver didn't build successfully.
Modified: cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.cpp
--- cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.cpp 2012-10-03 18:18:24 UTC (rev 5764)
+++ cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.cpp 2012-10-04 16:01:47 UTC (rev 5765)
@@ -122,6 +122,37 @@
+// Purpose : Add and update looplist for the curve, if input loop is
+// NULL, just update the looplist.
+// Special Notes :
+// Creator : Jane Hu
+// Creation Date : 10/04/12
+void OCCCurve::add_loop(OCCLoop* loop)
+ //before add the loop into the looplist, check to make sure the
+ //looplist is up-to-date
+ //It should be done somewhere else, however, in large mcnp2cad test, there's
+ //no way to check where the code forget to remove the out-dated loop.
+ for (int i = 0; i < myLoopList.size(); i++)
+ OCCLoop* myLoop = CAST_TO(myLoopList.get(), OCCLoop);
+ if(!myLoop)
+ this->remove_loop(myLoopList.get());
+ else if(myLoop->get_TopoDS_Wire() < (void*) 0x1000)
+ this->remove_loop(myLoop);
+ else if(myLoop->coedges().size() == 0)
+ myLoopList.step();
+ if(loop != NULL)
+ myLoopList.append_unique(loop);
void OCCCurve::set_TopoDS_Edge(TopoDS_Edge edge)
if(myTopoDSEdge && edge.IsEqual(*myTopoDSEdge))
@@ -755,6 +786,9 @@
void OCCCurve::get_parents_virt( DLIList<TopologyBridge*>& parents )
+ //check to see all myLoops are up-to-date.
+ add_loop(NULL);
for(int i = 0; i < myLoopList.size(); i++)
More information about the cgma-dev
