[cgma-dev] r5753 - in cgm/trunk: . geom util
csverma at mcs.anl.gov
Wed Sep 26 10:00:18 CDT 2012
Author: csverma
Date: 2012-09-26 10:00:18 -0500 (Wed, 26 Sep 2012)
New Revision: 5753
Modified:
cgm/trunk/configure.ac
cgm/trunk/geom/CubitGeomConfigure.h
cgm/trunk/util/CubitUtilConfigure.h
Log:
OCC works with freetype2 and new ftgl on Ubuntu12.04
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac 2012-09-25 18:33:05 UTC (rev 5752)
+++ cgm/trunk/configure.ac 2012-09-26 15:00:18 UTC (rev 5753)
@@ -533,7 +533,7 @@
AC_LINK_IFELSE(
[AC_LANG_PROGRAM([#include "Standard_Mutex.hxx"], [Standard_Mutex mutex; mutex.TryLock();])],
[AC_MSG_RESULT([yes]); OCC_LIBS="$OCC_LIBS -lpthread"],
- [AC_MSG_ERROR([Cannot link libTKKernel with Standard_Mutex])]
+ [AC_MSG_ERROR([Cannot link libTKernel with Standard_Mutex])]
Modified: cgm/trunk/geom/CubitGeomConfigure.h
--- cgm/trunk/geom/CubitGeomConfigure.h 2012-09-25 18:33:05 UTC (rev 5752)
+++ cgm/trunk/geom/CubitGeomConfigure.h 2012-09-26 15:00:18 UTC (rev 5753)
@@ -1 +1,26 @@
+#ifndef CUBIT_GEOM_CONFIGURE_H
+#define CUBIT_GEOM_CONFIGURE_H
+/* #undef CUBIT_GEOM_BUILD_SHARED_LIBS */
+#if defined(CUBIT_GEOM_BUILD_SHARED_LIBS)
+#if defined(cubit_geom_EXPORTS)
+# if defined(WIN32)
+# define CUBIT_GEOM_EXPORT __declspec(dllexport)
+# elif defined(__GNUC__) && __GNUC__ >= 4
+# define CUBIT_GEOM_EXPORT __attribute__ ((visibility("default")))
+# endif
+#else
+# define CUBIT_GEOM_EXPORT __declspec(dllimport)
+# endif
+#endif
+#endif
+#ifndef CUBIT_GEOM_EXPORT
#define CUBIT_GEOM_EXPORT
+#endif
+#endif
Modified: cgm/trunk/util/CubitUtilConfigure.h
--- cgm/trunk/util/CubitUtilConfigure.h 2012-09-25 18:33:05 UTC (rev 5752)
+++ cgm/trunk/util/CubitUtilConfigure.h 2012-09-26 15:00:18 UTC (rev 5753)
@@ -1 +1,26 @@
More information about the cgma-dev
