[cgma-dev] r5711 - cgm/branches/merge-cubit13.1/geom/OCC
    janehu at mcs.anl.gov
    Tue Aug 28 17:41:19 CDT 2012
Author: janehu
Date: 2012-08-28 17:41:19 -0500 (Tue, 28 Aug 2012)
New Revision: 5711
Modified:
   cgm/branches/merge-cubit13.1/geom/OCC/OCCBody.cpp
Log:
Updated for special case in mcnp2cad when a 2-lump body unite with others and becomes a single lump body. Passed cgm make check.
Modified: cgm/branches/merge-cubit13.1/geom/OCC/OCCBody.cpp
--- cgm/branches/merge-cubit13.1/geom/OCC/OCCBody.cpp	2012-08-28 22:40:49 UTC (rev 5710)
+++ cgm/branches/merge-cubit13.1/geom/OCC/OCCBody.cpp	2012-08-28 22:41:19 UTC (rev 5711)
@@ -607,13 +607,14 @@
   CubitBoolean updated = CUBIT_FALSE;
   if(!old_shape.IsNull() && old_shape.ShapeType() == TopAbs_COMPOUND &&
      !new_shape.IsNull() && new_shape.ShapeType() == TopAbs_COMPOUND &&
-     !old_shape.IsSame(new_shape) && M.Extent() == M_new.Extent())
+     !old_shape.IsSame(new_shape))
     //By updating underling solids, shells etc., the old_shape will get changed.
     //trying to make sure the the number of each entity in the old and new
     //shapes are the same, which means that nothing is delete, that we can
     //update the map here. Otherwise, when deleting solids, it'll delete the
-    //the old body and create new body. This is Ok for general boolean operation    //except imprint when booleans are called, usually the original body are
+    //the old body and create new body. This is Ok for general boolean operation
+    //except imprint when booleans are called, usually the original body are
     // supposed to be kept.
     updated = CUBIT_TRUE;
     OCCQueryEngine::instance()->update_OCC_map(old_shape, new_shape);
More information about the cgma-dev
