[cgma-dev] r5640 - cgm/branches/merge-cubit13.1/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Jul 26 10:43:59 CDT 2012
Author: janehu
Date: 2012-07-26 10:43:59 -0500 (Thu, 26 Jul 2012)
New Revision: 5640
Modified:
   cgm/branches/merge-cubit13.1/geom/OCC/OCCBody.cpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.cpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCLoop.cpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCLump.cpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCModifyEngine.cpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCPoint.cpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCQueryEngine.cpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCQueryEngine.hpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCShell.cpp
   cgm/branches/merge-cubit13.1/geom/OCC/OCCSurface.cpp
Log:
Updates for build with Opencascade6.5.3, passed cgm make check for occ6.5.2 and occ6.5.3 build.
Modified: cgm/branches/merge-cubit13.1/geom/OCC/OCCBody.cpp
--- cgm/branches/merge-cubit13.1/geom/OCC/OCCBody.cpp	2012-07-26 15:42:27 UTC (rev 5639)
+++ cgm/branches/merge-cubit13.1/geom/OCC/OCCBody.cpp	2012-07-26 15:43:59 UTC (rev 5640)
@@ -158,10 +158,9 @@
   else
-    TopoDS_Compound * the_comp = new TopoDS_Compound(theshape);
     if(myTopoDSShape)
-      delete (TopoDS_Compound*)myTopoDSShape;
-    myTopoDSShape = the_comp;
+      myTopoDSShape->Nullify();
+    *myTopoDSShape = theshape;
Modified: cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.cpp
--- cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.cpp	2012-07-26 15:42:27 UTC (rev 5639)
+++ cgm/branches/merge-cubit13.1/geom/OCC/OCCCurve.cpp	2012-07-26 15:43:59 UTC (rev 5640)
@@ -150,10 +150,9 @@
         point->remove_curve(this);
-  TopoDS_Edge* the_edge = new TopoDS_Edge(edge);
   if(myTopoDSEdge)
-    delete (TopoDS_Edge *)myTopoDSEdge;
-  myTopoDSEdge = the_edge;
+    myTopoDSEdge->Nullify();
+  *myTopoDSEdge = edge;
Modified: cgm/branches/merge-cubit13.1/geom/OCC/OCCLoop.cpp
--- cgm/branches/merge-cubit13.1/geom/OCC/OCCLoop.cpp	2012-07-26 15:42:27 UTC (rev 5639)
+++ cgm/branches/merge-cubit13.1/geom/OCC/OCCLoop.cpp	2012-07-26 15:43:59 UTC (rev 5640)
@@ -100,10 +100,9 @@
          curve->remove_loop(this);
-   TopoDS_Wire* the_wire = new TopoDS_Wire(loop);
    if(myTopoDSWire)
-     delete (TopoDS_Wire*)myTopoDSWire;
-   myTopoDSWire = the_wire;
+     myTopoDSWire->Nullify();
+   *myTopoDSWire = loop;
More information about the cgma-dev mailing list
