[cgma-dev] [Fathom] RGG tests
Rajeev Jain
jain at mcs.anl.gov
Mon Jul 23 09:06:58 CDT 2012
As of now, Cubit13.2 is not supported, cgm/trunk/ works with Cubit 12.2, there is a different branch 'cgm/branches/merge-cubit13.1/' that works with Cubit 13.1.
Rajeev
>________________________________
> From: Atanas Atanasov <atanasoa at in.tum.de>
>To: Rajeev Jain <jain at mcs.anl.gov>
>Cc: "fathom at lists.mcs.anl.gov" <fathom at lists.mcs.anl.gov>
>Sent: Monday, July 23, 2012 3:21 AM
>Subject: Re: [Fathom] RGG tests
>Hi i am using currently
>Cubit 13.2 and cgm 12.2.
>Regards,
>A.Atanasov
>On 07/21/2012 12:48 AM, Rajeev Jain wrote:
>Hi,
>>What is the geometry engine that you've used?
>>RGG relies on CGM's geometry engine for geometry creation.
>>It needs that MeshKit be built with CGM option with Cubit/OCC/ACIS geometry engine.
>>You could use your own mesh generation tool or software for assembly generation, CUBIT is not required.
>>'coregen' program can read in meshes in formats supported by MOAB. More: http://trac.mcs.anl.gov/projects/fathom/wiki/rgg
>>If you have the assembly meshes already done, you could skip 'assygen' step.
>>Rajeev
>>>To: fathom at lists.mcs.anl.gov
>>>Sent: Friday, July 20, 2012 2:26 AM
>>>Subject: [Fathom] RGG tests
>>>Hello ,
>>>i made a checkout of the current version of meshkit
together with rgg and tried to run the tests for rgg
(setup: current moab, cgm and lasso from itaps web
site). The assygen test fails with the following log:
>>> MESHKIT 0.9RC0: rgg/test-suite.log
>>>1 of 3 tests failed.
>>>.. contents:: :depth: 2
>>>FAIL: assygen (exit: 139)
>>>Starting out at : Fri Jul 20 09:13:56 2012
>>> Program to Generate Nuclear Reactor Assembly
Geometries
>>> Argonne National Laboratory
>>> 2009-2010
>>>see README file for using the program and details on
various cards.
>>>Instruction on writing assygen input file can also be
found at:
>>>https://trac.mcs.anl.gov/projects/fathom/browser/MeshKit/trunk/rgg/README
>>>Usage: assygen [-t -j -h] <input file name without
extension>
>>> -t print timing and memory usage info in each
step
>>> -j create journal file only
>>> -h print help
>>>Running default case:
>>> No file specified. Defaulting to:
./assygen_default.inp assygen_default.jou
>>>Entered input file name: ./assygen_default.inp
>>>o/p Cubit journal file name: assygen_default.jou
>>>o/p geometry file name: assygen_default
>>>assygen_default_info.csv
>>>getting assembly dimensions 1
>>>getting assembly dimensions 2
>>>getting volume id
>>>getting pitch data
>>>getting cylinder data
>>>getting frustum data
>>>read pincell 1
>>>m = 1 n = 1
>>>creating pin: 1 at X Y Z 0 -0 0
>>>Facet-based geometry modification is a beta capability.
>>>ERROR: This capability is currently disabled.
>>>To enable this capability, issue the command 'set
developer commands on'.
>>>ERROR: In GeometryModifyTool::cylinder
>>> Problems building a volume from the conical
frustum.
>>>ERROR: Couldn't create fuel rod.
>>> Error code: 22
>>> Error desc: Unknown failure or internal error
>>> At : io.cpp:2731
>>>m = 1 n = 2
>>>creating pin: 1 at X Y Z 4 -0 0
frustum.
>>> Error code: 22
>>> At : io.cpp:2731
>>>m = 1 n = 3
>>>creating pin: 1 at X Y Z 8 -0 0
frustum.
>>> Error code: 22
>>> At : io.cpp:2731
>>>m = 1 n = 4
>>>creating pin: 1 at X Y Z 12 -0 0
frustum.
>>> Error code: 22
>>> At : io.cpp:2731
>>>m = 4 n = 1
>>>creating pin: 1 at X Y Z 0 -12 0
frustum.
>>> Error code: 22
>>> At : io.cpp:2731
>>>m = 4 n = 2
>>>creating pin: 1 at X Y Z 4 -12 0
frustum.
>>> Error code: 22
>>> At : io.cpp:2731
>>>m = 4 n = 3
>>>creating pin: 1 at X Y Z 8 -12 0
frustum.
>>> Error code: 22
>>> At : io.cpp:2731
>>>m = 4 n = 4
>>>creating pin: 1 at X Y Z 12 -12 0
frustum.
>>> Error code: 22
>>> At : io.cpp:2731
>>>Creating surrounding outer blocks ..
>>>ERROR: In GeometryModifyTool::brick
>>> Problem creating a brick.
>>>ERROR: Prism creation failed.
>>> Error code: 22
>>> At : io.cpp:2149
>>>created innermost block: mat_block
>>>How can i fix this?
>>>PS: Is it possible to assemble the meshes without cubit
(directly into MOAB for instance)?
>>>Regards,
>>>A.Atanasov
>>>_______________________________________________
>>>Fathom mailing list
>>>Fathom at lists.mcs.anl.gov
>>>https://lists.mcs.anl.gov/mailman/listinfo/fathom
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120723/4c0f297b/attachment.html>
More information about the cgma-dev
