[cgma-dev] r5605 - cgm/branches/merge-cubit13.1/test
    jiangtao_ma at yahoo.com
    Thu Jun 28 10:56:52 CDT 2012
Author: janehu
Date: 2012-06-28 10:56:52 -0500 (Thu, 28 Jun 2012)
New Revision: 5605
Added:
   cgm/branches/merge-cubit13.1/test/attribute_to_file.cpp
   cgm/branches/merge-cubit13.1/test/imprint_bug.cpp
   cgm/branches/merge-cubit13.1/test/loft.cpp
   cgm/branches/merge-cubit13.1/test/offset_curves.cpp
   cgm/branches/merge-cubit13.1/test/point_project.cpp
Removed:
   cgm/branches/merge-cubit13.1/test/BsplineCurve.occ
   cgm/branches/merge-cubit13.1/test/after_webcut.brep
   cgm/branches/merge-cubit13.1/test/ellipses.occ
   cgm/branches/merge-cubit13.1/test/glue.occ
   cgm/branches/merge-cubit13.1/test/imprint.brep
   cgm/branches/merge-cubit13.1/test/subtract.occ
   cgm/branches/merge-cubit13.1/test/temp
   cgm/branches/merge-cubit13.1/test/webcut_sweep.brep
Modified:
   cgm/branches/merge-cubit13.1/test/Makefile.am
Log:
Added bug-fixing test-cases to here.
Deleted: cgm/branches/merge-cubit13.1/test/BsplineCurve.occ
--- cgm/branches/merge-cubit13.1/test/BsplineCurve.occ	2012-06-28 15:49:19 UTC (rev 5604)
+++ cgm/branches/merge-cubit13.1/test/BsplineCurve.occ	2012-06-28 15:56:52 UTC (rev 5605)
@@ -1,71 +0,0 @@
-DBRep_DrawableShape
-CASCADE Topology V1, (c) Matra-Datavision
-Locations 0
-Curve2ds 0
-Curves 2
-7 0 0  3 8 6  10 10 10  7.8962907194978245 9.9328755447232275 10  4.1504640997504039 8.1351109972144258 10.000000000000002  1.714602544470867 3.468838576501712 10.000000000000002  -0.24807223430422448 -0.53560957713195312 10  -2.9384040624443264 -5.4124904340469637 10.000000000000002  -6.2827475623092432 -8.8001177873989569 10  -10 -10 10
- 0 4 5.3851648071345037 1 12.596267358062482 1 14.832335335562272 1 18.863464209711545 1 29.171228273755695 4
-7 0 0  3 8 6  10 10 10  8.8666713916745454 8.8666713916745454 10  3.4843922940546812 8.8157357833931851 10.000000000000002  1.8844626692971531 3.4528242743597368 10.000000000000002  -0.4211062146432315 -0.57327939072379408 10  -0.88697691552815716 -4.7540936064134218 10.000000000000002  -17.604693546281354 -12.534897848760451 10  -10 -10 10
-Polygon3D 0
-PolygonOnTriangulations 0
-Surfaces 0
-Triangulations 0
-TShapes 7
-Ve
-1e-07
-10 10 10
-0 0
-0101101
-Ve
-1e-07
--10 -10 10
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  1 0 0 29.1712282737557
-0
-0101000
-+7 0 -6 0 *
-Ve
-1e-07
-10 10 10
-0 0
-0101101
-Ve
-1e-07
More information about the cgma-dev
