[cgma-dev] CGMA with ACIS
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Jun 18 11:54:01 CDT 2012
Actually, if you send us verification that you have a license for ACIS, we can send you the CGM/ACIS port too, then it's
just a matter of porting to the most recent version of ACIS.
- tim
On 06/18/2012 10:48 AM, Jane Hu wrote:
> Once you get CGM source code, I guess it's up to you on how to cooperate it with your version of ACIS.
> Jane
> On Mon, Jun 18, 2012 at 10:32 AM, peng peng <eliza_zheng at 126.com <mailto:eliza_zheng at 126.com>> wrote:
>     Hi
>         so, should I rewrite it in ACIS R21?
>     Thanks.
>     eliza
>     At 2012-06-18 22:18:37,"Jane Hu" <janejhu at gmail.com <mailto:janejhu at gmail.com>> wrote:
>         Hi, Eliza:
>         I think you are right, CGMA I think is compatible with Acis19 and under, Cubit is compatible with Acis19 too.
>         CGMA currently doesn't maintain the interface to Acis, Cubit is maintaining it. Hope it helps.
>         Jane
>         On Sun, Jun 17, 2012 at 9:29 PM, peng peng <eliza_zheng at 126.com <mailto:eliza_zheng at 126.com>> wrote:
>             Hi
>             I wondered whether CGMA could be compiled with ACIS R21, because
>             the related header files and libraries of CGMA couldn't be found in ACIS R21, what should I do? I have
>             consulted with Spatial, they said old version is not available now. Could you help me?
>             Thanks.
>             eliza
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
