[cgma-dev] r5569 - in cgm/trunk/geom: . Cholla facet facetbool
jvporter at wisc.edu
Tue Jun 12 15:38:41 CDT 2012
Author: jvporter
Date: 2012-06-12 15:38:40 -0500 (Tue, 12 Jun 2012)
New Revision: 5569
Modified:
cgm/trunk/geom/Cholla/Cholla.cpp
cgm/trunk/geom/Cholla/FacetDataUtil.cpp
cgm/trunk/geom/Cholla/FacetEvalTool.cpp
cgm/trunk/geom/SurfaceOverlapTool.cpp
cgm/trunk/geom/facet/FacetQueryEngine.cpp
cgm/trunk/geom/facetbool/FBIntersect.cpp
Log:
Fix more printf warnings
Modified: cgm/trunk/geom/Cholla/Cholla.cpp
--- cgm/trunk/geom/Cholla/Cholla.cpp 2012-06-12 19:54:25 UTC (rev 5568)
+++ cgm/trunk/geom/Cholla/Cholla.cpp 2012-06-12 20:38:40 UTC (rev 5569)
@@ -1901,11 +1901,11 @@
int kk;
for(kk=0; kk<3; kk++);
- fprintf(fp, "(%d) %.6lf %.6lf %.6lf\n", edge_ptr->id(), P0.x(), P0.y(), P0.z());
- fprintf(fp, " %.6lf %.6lf %.6lf\n", Pi[0].x(), Pi[0].y(), Pi[0].z());
- fprintf(fp, " %.6lf %.6lf %.6lf\n", Pi[1].x(), Pi[1].y(), Pi[1].z());
- fprintf(fp, " %.6lf %.6lf %.6lf\n", Pi[2].x(), Pi[2].y(), Pi[2].z());
- fprintf(fp, " %.6lf %.6lf %.6lf\n", P1.x(), P1.y(), P1.z());
+ fprintf(fp, "(%d) %.6f %.6f %.6f\n", edge_ptr->id(), P0.x(), P0.y(), P0.z());
+ fprintf(fp, " %.6f %.6f %.6f\n", Pi[0].x(), Pi[0].y(), Pi[0].z());
+ fprintf(fp, " %.6f %.6f %.6f\n", Pi[1].x(), Pi[1].y(), Pi[1].z());
+ fprintf(fp, " %.6f %.6f %.6f\n", Pi[2].x(), Pi[2].y(), Pi[2].z());
+ fprintf(fp, " %.6f %.6f %.6f\n", P1.x(), P1.y(), P1.z());
edge_ptr->control_points( Pi, 4 );
Modified: cgm/trunk/geom/Cholla/FacetDataUtil.cpp
--- cgm/trunk/geom/Cholla/FacetDataUtil.cpp 2012-06-12 19:54:25 UTC (rev 5568)
+++ cgm/trunk/geom/Cholla/FacetDataUtil.cpp 2012-06-12 20:38:40 UTC (rev 5569)
@@ -1270,7 +1270,7 @@
pt = point_list.get_and_step();
pt->set_id(ii);
- fprintf(fp, "%d %lf %lf %lf\n", ii, pt->x(), pt->y(), pt->z() );
+ fprintf(fp, "%d %f %f %f\n", ii, pt->x(), pt->y(), pt->z() );
CubitFacet *facet;
@@ -1800,7 +1800,7 @@
CubitVector loc_on_edge;
CubitBoolean is_on_edge;
double dist = edge->dist_to_edge(pt->coordinates(), loc_on_edge, is_on_edge);
- PRINT_INFO("edge %d dist = %lf is_on_edge = %d\n", edge->id(), dist, is_on_edge);
+ PRINT_INFO("edge %d dist = %f is_on_edge = %d\n", edge->id(), dist, is_on_edge);
dview();
pt = pt;
Modified: cgm/trunk/geom/Cholla/FacetEvalTool.cpp
--- cgm/trunk/geom/Cholla/FacetEvalTool.cpp 2012-06-12 19:54:25 UTC (rev 5568)
+++ cgm/trunk/geom/Cholla/FacetEvalTool.cpp 2012-06-12 20:38:40 UTC (rev 5569)
@@ -2308,7 +2308,7 @@
if (normal_ptr) {
More information about the cgma-dev
