[cgma-dev] r5567 - cgm/trunk/geom
    jvporter at wisc.edu
    Tue Jun 12 14:34:03 CDT 2012
Author: jvporter
Date: 2012-06-12 14:34:03 -0500 (Tue, 12 Jun 2012)
New Revision: 5567
Modified:
   cgm/trunk/geom/CAEntityId.cpp
   cgm/trunk/geom/GeomMeasureTool.cpp
   cgm/trunk/geom/GeometryQueryTool.cpp
Log:
Remove some more warnings
Modified: cgm/trunk/geom/CAEntityId.cpp
--- cgm/trunk/geom/CAEntityId.cpp	2012-06-12 18:48:25 UTC (rev 5566)
+++ cgm/trunk/geom/CAEntityId.cpp	2012-06-12 19:34:03 UTC (rev 5567)
@@ -63,9 +63,11 @@
    DLIList<double*> *d_list = csa_ptr->double_data_list();
    if (d_list && d_list->size() > 0) {
+#ifndef NDEBUG
      RefEdge *edge = CAST_TO(new_attrib_owner, RefEdge);
      assert(d_list->size() == 3 &&
             edge && edge->start_vertex() == edge->end_vertex());
+#endif
      d_list->reset();
      boundingXYZ = new CubitVector(*d_list->get_and_step(),
Modified: cgm/trunk/geom/GeomMeasureTool.cpp
--- cgm/trunk/geom/GeomMeasureTool.cpp	2012-06-12 18:48:25 UTC (rev 5566)
+++ cgm/trunk/geom/GeomMeasureTool.cpp	2012-06-12 19:34:03 UTC (rev 5567)
@@ -1899,7 +1899,6 @@
                                           DLIList <RefFace*> &surfs_with_narrow_regions)
   int j;
-  double tol_sq = tol*tol;
   int ii, jj;
   DLIList <RefFace*> ref_faces, temp_faces;
@@ -1991,7 +1990,6 @@
       int num_incs = (int)(edge_length/small_curve_size) + 1;
       double start, end;
       cur_edge->get_param_range(start, end);
-      double dt = small_curve_size*((end-start)/edge_length);
       double t = start;
       bool one_bad = false;
       for(j=0; j<num_incs && ret == true; j++)
@@ -2268,8 +2266,6 @@
   int ret = 0;
-  double small_step = 5.0*tol;
-  double small_step_sq = small_step*small_step;
   double max_dist_sq = 0.0;
   RefVertex *e1_start_vert = e1->start_vertex();
   RefVertex *e1_end_vert = e1->end_vertex();
@@ -2474,8 +2470,6 @@
     e2_vert_list.reset();
     for(i=e1_pos_list.size(); i--;)
-      CubitVector *e1_pos = e1_pos_list.get_and_step();
More information about the cgma-dev
