[cgma-dev] r5557 - cgm/trunk/itaps
    jvporter at wisc.edu
    Fri Jun  8 11:05:04 CDT 2012
Author: jvporter
Date: 2012-06-08 11:05:04 -0500 (Fri, 08 Jun 2012)
New Revision: 5557
Modified:
   cgm/trunk/itaps/iGeom_CGMA.cc
Log:
* Fix fread checks
* Make .cub file magic string check actually work
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc	2012-06-07 23:00:08 UTC (rev 5556)
+++ cgm/trunk/itaps/iGeom_CGMA.cc	2012-06-08 16:05:04 UTC (rev 5557)
@@ -6554,7 +6554,7 @@
 void
 iGeom_load_cub_geometry(const char *name, int* err)
-  size_t bytes_read;
+  size_t items_read;
   FILE *cubfile = fopen(name, "rb");
   if (NULL == cubfile) RETURN(iBase_FILE_NOT_FOUND);
@@ -6566,25 +6566,28 @@
   long endpos = ftell(cubfile);
-  char magic_str[4] = {'\0', '\0', '\0', '\0'};
-  bytes_read = fread(magic_str, 1, 4, cubfile);
-  if (bytes_read != 4) {
-    ERROR(iBase_FAILURE, "Error reading .cub file");
+  result = fseek(cubfile, 0, 0 /*SEEK_SET*/);
+  if (result) {
+    ERROR(iBase_FAILURE, "Seek failed reading cub file header.");
-  if (!strcmp(magic_str, "CUBE")) {
+  char magic_str[5] = "";
+  items_read = fread(magic_str, 1, 4, cubfile);
+  if (items_read != 4) {
+    ERROR(iBase_FAILURE, "Error reading .cub file magic string");
+  if (strcmp(magic_str, "CUBE")) {
     ERROR(iBase_NOT_SUPPORTED, "Wrong magic string in .cub file.");
     // get the model header
-  //result = fseek(cubfile, 4, SEEK_SET);
-  result = fseek(cubfile, 4, 0);
+  result = fseek(cubfile, 4, 0 /*SEEK_SET*/);
   if (result) {
-    ERROR(iBase_FAILURE, "Seek failed reading cub file header.");
+    ERROR(iBase_FAILURE, "Seek failed reading after cub file header.");
   int header[6];
-  bytes_read = fread(header, 4, 6, cubfile);
-  if (bytes_read != 4*6) {
+  items_read = fread(header, 4, 6, cubfile);
+  if (items_read != 6) {
More information about the cgma-dev
