[cgma-dev] r5446 - in cgm/trunk: . geom/ACIS itaps
    jvporter at wisc.edu
    Fri Mar 23 21:15:46 CDT 2012
Author: jvporter
Date: 2012-03-23 21:15:45 -0500 (Fri, 23 Mar 2012)
New Revision: 5446
Modified:
   cgm/trunk/configure.ac
   cgm/trunk/geom/ACIS/Makefile.am
   cgm/trunk/itaps/CATag.cpp
   cgm/trunk/itaps/CATag.hpp
   cgm/trunk/itaps/Makefile.am
   cgm/trunk/itaps/iGeomError.cc
   cgm/trunk/itaps/iGeomError.h
   cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Add hooks for ITAPS shim (let's hope this doesn't break everything!)
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac	2012-03-23 05:48:33 UTC (rev 5445)
+++ cgm/trunk/configure.ac	2012-03-24 02:15:45 UTC (rev 5446)
@@ -393,6 +393,13 @@
 AC_SUBST(USE_BABEL)
 AM_CONDITIONAL(USE_BABEL, [test "xno" != "x$USE_BABEL"])
+#                           ITAPS shim
+AC_ARG_ENABLE([shim],[AC_HELP_STRING([--enable-shim],
+  [Enable ITAPS shim])],
+  [ITAPS_SHIM=$enableval],[ITAPS_SHIM=no])
+AM_CONDITIONAL([ITAPS_SHIM],[test "xyes" = "x$ITAPS_SHIM"])
 #                           OCC Options
Modified: cgm/trunk/geom/ACIS/Makefile.am
--- cgm/trunk/geom/ACIS/Makefile.am	2012-03-23 05:48:33 UTC (rev 5445)
+++ cgm/trunk/geom/ACIS/Makefile.am	2012-03-24 02:15:45 UTC (rev 5446)
@@ -0,0 +1,89 @@
+AM_CPPFLAGS += $(ACIS_STEP_TRANSLATOR) \
+               $(ACIS_IGES_TRANSLATOR) \
+               -DCUBIT_ACIS_VERSION=$(ACIS_VERSION) \
+               -DACIS_VERSION=$(ACIS_VERSION) \
+               -DACIS_VER=$(ACIS_VERSION) \
+               -D$(ACIS_PLATFORM) \
+               -DACIS_LOCAL_OPS \
+               -I$(top_srcdir)/util \
+               -I$(top_srcdir)/geom \
+               -I$(srcdir)/gtcAttrib/incl \
+                $(ACIS_INCLUDES)
+# The name of the library to build
+noinst_LTLIBRARIES = libcubit_ACIS.la
+# The directory where headers will be installed
+libcubit_ACIS_la_includedir = $(includedir)
+# The non-template sources
+libcubit_ACIS_la_SOURCES = \
+    AcisBridge.cpp \
+    AcisEdgeTool.cpp \
+    AcisFacetManager.cpp \
+    AcisFeatureEngine.cpp \
+    AcisHealerTool.cpp \
+    AcisHistory.cpp \
+    AcisModifyEngine.cpp \
More information about the cgma-dev
