[cgma-dev] OCC based CGM with openmpi
Iulian Grindeanu
iulian at mcs.anl.gov
Tue Mar 20 18:56:22 CDT 2012
const should be removed. If it compiles for you without 'const', you should commit it. It passes make check for me (when I removed const) ----- Original Message -----
| It get the following message when compiling:
| libtool: compile: /usr/local/bin/mpicxx -DHAVE_CONFIG_H -I. -I..
| -I../geom/parallel -I../geom -DLITTLE_ENDIAN=BYTE_ORDER
| -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP
| -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init
| -I../geom/parallel -DUSE_MPI -Wall -pipe -pedantic -g -MT CATag.lo -MD
| -MP -MF .deps/CATag.Tpo -c CATag.cpp -o CATag.o >/dev/null 2>&1
| iGeom_CGMA.cc:6882:19: error: cannot initialize a variable of type
| 'TopologyEntity *' with an rvalue of type
| 'const TopologyEntity *'
| TopologyEntity *topo_ent = dynamic_cast<const TopologyEntity*>(face);
| 1 warning and 1 error generated.
| make[4]: *** [iGeom_CGMA.lo] Error 1
| make[4]: *** Waiting for unfinished jobs....
| mv -f .deps/CATag.Tpo .deps/CATag.Plo
| make[3]: *** [all-recursive] Error 1
| make[2]: *** [all] Error 2
| make[1]: *** [all-recursive] Error 1
| make: *** [all] Error 2
| Rajeev
| This is on Mac OSX Lion
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120320/389e3b1a/attachment.htm>
More information about the cgma-dev
