[cgma-dev] OCC MacOS compile successful
Rajeev Jain jain at mcs.anl.gov
Tue Feb 28 11:41:07 CST 2012
Thanks, Jane. I made a couple of changes in addition to checking out the latest version and recompilng:
1. Installed gcc -4.7 (The previous error might be a compiler issue as per http://www.opencascade.org/org/forum/thread_19739/)
2. Applied the OCC652 patch in cgm/geom/occ
make works !
make check gives me this error
make  check-TESTS
Geometry engine set to: OpenCascade 6.5
      ...    Step File Reading : ilc_13body.stp
      ...    STEP File   Read    ...
Elapsed time: 0 Hours 0 Minutes 0.007108 Seconds
CPU user time: 0.01 seconds
CPU system time: 0 seconds
  ***  Error on Record 648 (on 9879 -> 6 % in File)  ***  Ident #479
Complex Type incorrect : SOLID_ANGLE_UNIT / SI_UNIT ...
  ***  Error on Record 862 (on 9879 -> 8 % in File)  ***  Ident #650
Complex Type incorrect : NAMED_UNIT / LENGTH_UNIT ...
  ***  Error on Record 1489 (on 9879 -> 15 % in File)  ***  Ident #1115
Complex Type incorrect : RATIONAL_B_SPLINE_CURVE / BOUNDED_CURVE ...
  ***  Error
 ***  Error on Record 2660 (on 9879 -> 26 % in File)  ***  Ident #1444
Complex Type incorrect : GEOMETRIC_REPRESENTATION_ITEM / CURVE ...
      ... Step File loaded  ...
Elapsed time: 0 Hours 0 Minutes 0.01294 Seconds
   9879 records (entities,sub-lists,scopes), 29736 parameters
      ... Parameters prepared ... Elapsed time: 0 Hours 0 Minutes 0.016723 Seconds
CPU user time: 0.02 seconds
Report : 75 unknown entities
      ...   Objets analysed  ...
Elapsed time: 0 Hours 0 Minutes 0.023135 Seconds
  STEP Loading done : 5784 Entities
/bin/sh: line 1: 29000 Segmentation fault: 11  ${dir}$tst
FAIL: test_edge_orient
Using default input file: ./../test/LeverArm.brep
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
/bin/sh: line 1: 29019 Segmentation fault: 11  ${dir}$tst
FAIL: testgeom_occ
Creating Prism
terminate called throwing an exception
/bin/sh: line 1: 29037 Abort trap: 6           ${dir}$tst
FAIL: copy_attrib
3 of 3 tests failed
make[4]: *** [check-TESTS] Error 1
make[3]: *** [check-am] Error 2
make[2]: *** [check-recursive] Error 1
make[1]: *** [check] Error 2
make: *** [check-recursive] Error 1
Rajeev
>________________________________
> From: Jane Hu <janejhu at gmail.com>
>To: Rajeev Jain <jain at mcs.anl.gov>
>Cc: Tim Tautges <tautges at mcs.anl.gov>; CGMA Development <cgma-dev at mcs.anl.gov>; James Tautges <jamesdtautges at gmail.com>
>Sent: Tuesday, February 28, 2012 10:28 AM
>Subject: Re: [cgma-dev] OCC MacOS compile successful
>Hi, Rajeev,
>I just checked in r5411, please update your cgm to see if it fixes the problem.
>Jane
>On Mon, Feb 27, 2012 at 2:22 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
>Right, I was missing DYLD_LBRARY_PATH. CGM configures now, make runs for a while then I get the following error:
>>In copy constructor 'BRepBuilderAPI_MakeShape::BRepBuilderAPI_MakeShape(const BRepBuilderAPI_MakeShape&)':
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/TopTools_ListOfShape.hxx:112: error: 'TopTools_ListOfShape::TopTools_ListOfShape(const TopTools_ListOfShape&)' is private
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepBuilderAPI_MakeShape.hxx:38: error: within this context
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepBuilderAPI_MakeWire.hxx: In copy constructor 'BRepBuilderAPI_MakeWire::BRepBuilderAPI_MakeWire(const BRepBuilderAPI_MakeWire&)':
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepBuilderAPI_MakeWire.hxx:66: note: synthesized method 'BRepBuilderAPI_MakeShape::BRepBuilderAPI_MakeShape(const BRepBuilderAPI_MakeShape&)' first required here
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/TopTools_ListOfShape.hxx: In copy constructor 'BRepLib_MakeShape::BRepLib_MakeShape(const BRepLib_MakeShape&)':
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepLib_MakeShape.hxx:46: error: within this context
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepLib_MakeWire.hxx: In copy constructor 'BRepLib_MakeWire::BRepLib_MakeWire(const BRepLib_MakeWire&)':
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepLib_MakeWire.hxx:81: note: synthesized method 'BRepLib_MakeShape::BRepLib_MakeShape(const BRepLib_MakeShape&)' first required here
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/TopTools_MapOfShape.hxx:88: error: 'TopTools_MapOfShape::TopTools_MapOfShape(const TopTools_MapOfShape&)' is private
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepLib_MakeWire.hxx:81: error: within this context
>>/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepBuilderAPI_MakeWire.hxx:66: note: synthesized method 'BRepLib_MakeWire::BRepLib_MakeWire(const BRepLib_MakeWire&)' first required here
>>OCCModifyEngine.cpp: In member function 'CubitStatus OCCModifyEngine::do_loft(BRepOffsetAPI_ThruSections&, DLIList<DLIList<TopoDS_Edge*>*>) const':
>>OCCModifyEngine.cpp:952: note: synthesized method 'BRepBuilderAPI_MakeWire::BRepBuilderAPI_MakeWire(const BRepBuilderAPI_MakeWire&)' first required here
>>make[4]: *** [OCCModifyEngine.lo] Error 1
>>make[3]: *** [all-recursive] Error 1
>>make[2]: *** [all] Error 2
>>make[1]: *** [all-recursive] Error 1
>>make: *** [all] Error 2
>>Rajeev
>>>Sent: Monday, February 27, 2012 9:42 AM
>>>Hi, Rajeev:
>>>It's good news that you are able to build OCC in Mac!
>>>I saw this error before too in building CGM on OCC on Linux. However, it turned out to be a set up problem. Can you look at config.log, and check if it said that you are using the correctly OCC library? You have to set the LD_LIBRARY_PATH to include your new build directory.
>>>Hope it helps.
>>>Jane
>>>On Fri, Feb 24, 2012 at 12:21 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
>>>Thanks, James.
>>>>I was able to build OCC. Did you get CGM to work?
>>>>Configuring CGM I get this:
>>>>checking if OpenCascade requires -lpthread... configure: error: Cannot link libTKKernel with Standard_Mutex
>>>>Rajeev
>>>>> From: Tim Tautges <tautges at mcs.anl.gov>
>>>>>To: CGMA Development <cgma-dev at mcs.anl.gov>; James Tautges <jamesdtautges at gmail.com>
>>>>>Sent: Friday, January 6, 2012 9:10 AM
>>>>>Subject: [cgma-dev] OCC MacOS compile successful
>>>>>Hi all,
>>>>>  Good news, last night my son James, hacker extraordinaire, got OCC 6.5.2 to compile successfully on MacOS.  The details:
>>>>>- Snow leopard, gcc4.2, OCC6.5.2 (straight from the OCC download page)
>>>>>- Besides the following changes, follow the steps on http://opencascade.blogspot.com/2010/04/porting-on-macos.html
>>>>>- Run "autoreconf -fi" in the ros folder and then "aclocal", "automake", and "autoconf"
>>>>>- Add the following code to the platform specific part of ros/src/OSD/OSD_Chronometer.cxx:
>>>>>#ifdef __MACH__
>>>>># include <time.h>
>>>>># include <sys/time.h>
>>>>># include <mach/clock.h>
>>>>># include <mach/mach.h>
>>>>>#endif
>>>>>- And then add this code to the OSD_Chronometer::GetThreadCPU function:
>>>>>#elif defined(__MACH__)
>>>>>  struct timespec ts;
>>>>>  clock_serv_t cclock;
>>>>>  mach_timespec_t mts;
>>>>>  host_get_clock_service(mach_host_self(), CALENDAR_CLOCK,
 &cclock);
>>>>>  clock_get_time(cclock, &mts);
>>>>>  mach_port_deallocate(mach_task_self(), cclock);
>>>>>  ts.tv_sec = mts.tv_sec;
>>>>>  ts.tv_nsec = mts.tv_nsec;
>>>>>- Proceed to configure, make, and install
>>>>>The new version of OSD_Chronometer.cxx is attached.
>>>>>We haven't built or tested CGM on top of this, but that's next.
>>>>>- tim
>>>>>"You will keep in perfect peace him whose mind is
>>>>>  steadfast, because he trusts in you."               Isaiah 26:3
>>>>>             Tim Tautges            Argonne National Laboratory
>>>>>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>>>>phone (gvoice): (608)
 354-1459      1500 Engineering Dr.
>>>>>            fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120228/4d1517a9/attachment.htm>
More information about the cgma-dev mailing list
