[cgma-dev] r5393 - in cgm/branches/cubit13.1/geom: . ACIS_SRC
    jiangtao_ma at yahoo.com
    Mon Feb 13 10:17:14 CST 2012
Author: janehu
Date: 2012-02-13 10:17:11 -0600 (Mon, 13 Feb 2012)
New Revision: 5393
Added:
   cgm/branches/cubit13.1/geom/ACIS_SRC/
Removed:
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisBridge.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisBridge.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisDrawTool.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisDrawTool.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisEdgeTool.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisEdgeTool.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisFacetManager.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisFacetManager.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisFeatureEngine.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisFeatureEngine.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisHealerTool.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisHealerTool.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisToolUtil.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisToolUtil.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisTweakTool.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/AcisTweakTool.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/Makefile
   cgm/branches/cubit13.1/geom/ACIS_SRC/Makefile.in
   cgm/branches/cubit13.1/geom/ACIS_SRC/attrib_cubit_owner.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/attrib_cubit_owner.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/attrib_snl.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/attrib_snl.o
   cgm/branches/cubit13.1/geom/ACIS_SRC/attrib_snl_simple.lo
   cgm/branches/cubit13.1/geom/ACIS_SRC/attrib_snl_simple.o
Log:
Add ACIS files to ACIS_SRC.
Deleted: cgm/branches/cubit13.1/geom/ACIS_SRC/AcisBridge.lo
--- cgm/branches/cubit13.1/geom/ACIS/AcisBridge.lo	2012-02-10 18:30:46 UTC (rev 5389)
+++ cgm/branches/cubit13.1/geom/ACIS_SRC/AcisBridge.lo	2012-02-13 16:17:11 UTC (rev 5393)
@@ -1,12 +0,0 @@
-# AcisBridge.lo - a libtool object file
-# Generated by ltmain.sh (GNU libtool) 2.2.6b Debian-2.2.6b-2ubuntu1
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# Name of the PIC object.
-pic_object=none
-# Name of the non-PIC object
-non_pic_object='AcisBridge.o'
Deleted: cgm/branches/cubit13.1/geom/ACIS_SRC/AcisBridge.o
(Binary files differ)
Deleted: cgm/branches/cubit13.1/geom/ACIS_SRC/AcisDrawTool.lo
--- cgm/branches/cubit13.1/geom/ACIS/AcisDrawTool.lo	2012-02-10 18:30:46 UTC (rev 5389)
+++ cgm/branches/cubit13.1/geom/ACIS_SRC/AcisDrawTool.lo	2012-02-13 16:17:11 UTC (rev 5393)
@@ -1,12 +0,0 @@
-# AcisDrawTool.lo - a libtool object file
-pic_object=none
-non_pic_object='AcisDrawTool.o'
Deleted: cgm/branches/cubit13.1/geom/ACIS_SRC/AcisDrawTool.o
Deleted: cgm/branches/cubit13.1/geom/ACIS_SRC/AcisEdgeTool.lo
--- cgm/branches/cubit13.1/geom/ACIS/AcisEdgeTool.lo	2012-02-10 18:30:46 UTC (rev 5389)
+++ cgm/branches/cubit13.1/geom/ACIS_SRC/AcisEdgeTool.lo	2012-02-13 16:17:11 UTC (rev 5393)
@@ -1,12 +0,0 @@
-# AcisEdgeTool.lo - a libtool object file
More information about the cgma-dev
