[cgma-dev] create surface skin bug
    Jane Hu
    janejhu at gmail.com
    Thu Feb  9 10:26:30 CST 2012
Hi, Boyd:
Here's another fix for create skin surface. Please feel free the test it
out. Testcase is at trunk/test/loft.cpp.
Thanks.
Jane
On Fri, Dec 23, 2011 at 1:40 PM, Boyd Tidwell <boyd at csimsoft.com> wrote:
> The following:
>    create vertex 0 0 0
>    create vertex 1 0 0
>    create vertex 0 1 0
>    create vertex 1 1 0
>    create curve vertex 1 2
>    create curve vertex 3 4
>    create surface skin curve 1 2
> does not work correctly.  The create surface command returns with no
> message of any sort but it is obvious the command failed because no surface
> is created.  Debug shows that the OCCModifyEngine::sort_curves method
> called from OCCModifyEngine::make_Surface (the one which takes a curve_list
> as input) returned CUBIT_FAILURE which aborts the command.  I traced
> through execution of sort_curves but was not able to determine exactly what
> the problem was but it obviously comes to the wrong conclusion concerning
> the curves to be sorted.
> Thanks muchly,
>   - Boyd
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120209/2bd8f242/attachment.htm>
More information about the cgma-dev
