[cgma-dev] create body loft bug
Jane Hu janejhu at gmail.com
Fri Feb 3 11:32:52 CST 2012
Hi, Boyd:
Here's another one that I just fixed. The testcase is in trunk
test/loft.cpp. Thank you for reporting the bug.
Jane
On Wed, Dec 28, 2011 at 11:24 AM, Boyd Tidwell <boyd at csimsoft.com> wrote:
> The commands:
>      brick x 10
>      move body 1 loc 22 13 11
>      brick x 10
>      create body loft surf 8 1
> gives the results:
>     ERROR: Surface1 must have only one loop.
> Yet, a "list surface 8" shows:
> Surface Entity  (Id = 8)
>     Visible:    Yes
>     Meshed:        No
>     Mesh Scheme:    map    (default)
>     Smooth Scheme:    winslow fixed
>     Periodic Intervals:    N/A
>     Interval Count:    Not Set
>     Interval Size:    Not Set
>     An odd loop:    No    (Surface 8)
>     Block Id:    0
>     4 curves in 1 loop.
>     Visible:    Yes
>                       Mesh Scheme  Arc      Interval:      Edge   Vertex
> Type
> ______Name_____    Id  +is meshed  Length   Count    Size  Length Start_T
> End_T
>        Curve 17    17      equal-      10     1         1      10
> 13     14
>        Curve 18    18      equal-      10     1         1      10
> 13     15
>        Curve 19    19      equal-      10     1         1      10
> 15     16
>        Curve 20    20      equal-      10     1         1      10
> 14     16
>     In Volume 2.
> It appears that surface 8 has exactly one loop so the ERROR message is
> wrong.
> Thanks very much,
>   - Boyd
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120203/5efd1d8d/attachment.htm>
More information about the cgma-dev mailing list
