[cgma-dev] buildbot failure in cgm-shared: failed compile test
James Porter jvporter at wisc.edu
Tue Jan 24 16:37:38 CST 2012
On Tue, 2012-01-24 at 10:32 -0600, Iulian Grindeanu wrote:
> I think it is a clean build, so I am surprised it fails. Could be that
> a "make distclean" is needed in this case? I think we do "make clean"
> in the build space.
Should be fixed. The buildbot will now run `make distclean` on all the
builds now.
More information about the cgma-dev mailing list
