[cgma-dev] buildbot failure in cgm-shared: failed compile test
Jane Hu
janejhu at gmail.com
Tue Jan 24 10:02:34 CST 2012
I've double checked by re-checked out the cgm trunk and build with
Opencascade6.5.1. It built ok and passed cgm make check. I am not sure
where the problem is. Someone has any thought?
Jane
On Tue, Jan 24, 2012 at 12:59 AM, <cgma-dev at mcs.anl.gov> wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-shared<http://gnep.mcs.anl.gov:8010/builders/cgm-shared>build
> #690 <http://gnep.mcs.anl.gov:8010/builders/cgm-shared/builds/690> *
> Results:*failed compile test *Buildslave:*gnep *Revision:*None *Reason:*The
> Nightly scheduler named 'cgm-shared-nightly' triggered this build Log
> Excerpt
> in a given directory, LIBDIR, you must either use libtool, and
> specify the full pathname of the library, or use the `-LLIBDIR'
> flag during linking and do at least one of the following:
> - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
> during execution
> - add LIBDIR to the `LD_RUN_PATH' environment variable
> during linking
> - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
> - have your system administrator add LIBDIR to `/etc/ld.so.conf'
> See any operating system documentation about shared libraries for
> more information, such as the ld(1) and ld.so(8) manual pages.
> test -z "/home/fathom/libs/current/cgm-shared/lib" || /bin/mkdir -p "/home/fathom/libs/current/cgm-shared/lib"
> /usr/bin/install -c -m 644 iGeom-Defs.inc '/home/fathom/libs/current/cgm-shared/lib'
> test -z "/home/fathom/libs/current/cgm-shared/include" || /bin/mkdir -p "/home/fathom/libs/current/cgm-shared/include"
> /usr/bin/install -c -m 644 iBase.h iGeom.h iGeom_FCDefs.h iGeom_protos.h iBase_f.h iGeom_f.h '/home/fathom/libs/current/cgm-shared/include'
> make install-data-hook
> make[6]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/itaps'
> echo "IGEOM_CXX_LDFLAGS = -L/home/fathom/libs/current/cgm-shared/lib" >> /home/fathom/libs/current/cgm-shared/lib/iGeom-Defs.inc
> echo "IGEOM_CXX_LTFLAGS = -R/home/fathom/libs/current/cgm-shared/lib" >> /home/fathom/libs/current/cgm-shared/lib/iGeom-Defs.inc
> echo "IGEOM_INCLUDEDIR = /home/fathom/libs/current/cgm-shared/include" >> /home/fathom/libs/current/cgm-shared/lib/iGeom-Defs.inc
> echo 'IGEOM_INCLUDES = -I$(IGEOM_INCLUDEDIR)' >> /home/fathom/libs/current/cgm-shared/lib/iGeom-Defs.inc
> ...Making install in test
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/test'
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/test'
> make[3]: Nothing to be done for `install-exec-am'.
> make[3]: Nothing to be done for `install-data-am'.
> ...Making install in cgm_apps
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/cgm_apps'
> Making install in examples
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/cgm_apps/examples'
> Making install in facetdriver
> make[4]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/cgm_apps/examples/facetdriver'
> make[5]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/cgm_apps/examples/facetdriver'
> make[5]: Nothing to be done for `install-exec-am'.
> make[5]: Nothing to be done for `install-data-am'.
> ...make[4]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/cgm_apps/examples'
> make[5]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/cgm_apps/examples'
> ...make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/cgm_apps'
> make[4]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/cgm_apps'
> make[4]: Nothing to be done for `install-exec-am'.
> make[4]: Nothing to be done for `install-data-am'.
> ...Making install in geom/testing
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/geom/testing'
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-shared/build/geom/testing'
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120124/61e809c6/attachment.htm>
More information about the cgma-dev
