[cgma-dev] r5340 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Mon Jan 23 12:35:17 CST 2012
Author: janehu
Date: 2012-01-23 12:35:17 -0600 (Mon, 23 Jan 2012)
New Revision: 5340
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
Change the code back to be compatible to Cubit interface and keep CGM a unitless system.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2012-01-23 18:15:39 UTC (rev 5339)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2012-01-23 18:35:17 UTC (rev 5340)
@@ -850,7 +850,6 @@
const char* file_name,
const char* file_type,
const CubitString &,
- const char* unit,
const char*)
if( strcmp( file_type, "OCC" ) != 0 &&
@@ -861,14 +860,16 @@
return CUBIT_FAILURE;
char* name = "write.iges.unit";
Standard_CString orig_unit;
+ char* unit = "M";
if(strcmp( file_type, "IGES") == 0 && unit != NULL)
orig_unit = Interface_Static::CVal(name);
Interface_Static::SetCVal (name, unit);
DLIList<OCCBody*> OCC_bodies;
DLIList<OCCSurface*> OCC_surfaces;
DLIList<OCCCurve*> OCC_curves;
@@ -931,10 +932,11 @@
status = write_topology( file_name, file_type,
OCC_bodies, OCC_surfaces,
OCC_curves, OCC_points );
//set the unit back.
Interface_Static::SetCVal (name,orig_unit);
if( status == CUBIT_FAILURE ) return CUBIT_FAILURE;
if( free_body_count || free_surface_count ||
@@ -1477,8 +1479,7 @@
CubitBoolean import_surfaces,
CubitBoolean import_curves,
CubitBoolean import_vertices,
- CubitBoolean free_surfaces,
- const char* unit )
+ CubitBoolean free_surfaces)
More information about the cgma-dev
