[cgma-dev] r5338 - cgm/trunk/geom/facet
jiangtao_ma at yahoo.com
Mon Jan 23 11:59:45 CST 2012
Author: janehu
Date: 2012-01-23 11:59:45 -0600 (Mon, 23 Jan 2012)
New Revision: 5338
Modified:
cgm/trunk/geom/facet/FacetQueryEngine.cpp
cgm/trunk/geom/facet/FacetQueryEngine.hpp
Log:
Change the code back to be compatible to Cubit interface and keep CGM a unitless system.
Modified: cgm/trunk/geom/facet/FacetQueryEngine.cpp
--- cgm/trunk/geom/facet/FacetQueryEngine.cpp 2012-01-23 17:56:39 UTC (rev 5337)
+++ cgm/trunk/geom/facet/FacetQueryEngine.cpp 2012-01-23 17:59:45 UTC (rev 5338)
@@ -702,7 +702,6 @@
const char* file_name,
const char* file_type,
const CubitString &,
- const char*,
const char*)
if( strcmp( file_type, "FACET" ) )
@@ -1752,8 +1751,7 @@
CubitBoolean import_surfaces,
CubitBoolean import_curves,
CubitBoolean import_vertices,
- CubitBoolean free_surfaces,
- const char* unit) //not used
+ CubitBoolean free_surfaces)
errno = 0;
FILE *file_ptr = fopen(file_name, "rb");
Modified: cgm/trunk/geom/facet/FacetQueryEngine.hpp
--- cgm/trunk/geom/facet/FacetQueryEngine.hpp 2012-01-23 17:56:39 UTC (rev 5337)
+++ cgm/trunk/geom/facet/FacetQueryEngine.hpp 2012-01-23 17:59:45 UTC (rev 5338)
@@ -249,7 +249,6 @@
const CubitString &cubit_version,
- const char* unit = NULL,
const char* logfile_name = NULL );
virtual CubitStatus export_solid_model( DLIList<TopologyBridge*>& bridge_list,
@@ -278,9 +277,7 @@
CubitBoolean import_surfaces = CUBIT_TRUE,
CubitBoolean import_curves = CUBIT_TRUE,
CubitBoolean import_vertices = CUBIT_TRUE,
- CubitBoolean free_surfaces = CUBIT_TRUE,
+ CubitBoolean free_surfaces = CUBIT_TRUE );
virtual CubitStatus import_solid_model(DLIList<TopologyBridge*> &imported_entities,
const char* pBuffer,
More information about the cgma-dev
