[cgma-dev] r5316 - cgm/trunk/test
    jiangtao_ma at yahoo.com
    Fri Jan 13 10:27:14 CST 2012
Author: janehu
Date: 2012-01-13 10:27:09 -0600 (Fri, 13 Jan 2012)
New Revision: 5316
Added:
   cgm/trunk/test/Solid_2.brep
Log:
Added brep file for test imprint_bug.
Added: cgm/trunk/test/Solid_2.brep
--- cgm/trunk/test/Solid_2.brep	                        (rev 0)
+++ cgm/trunk/test/Solid_2.brep	2012-01-13 16:27:09 UTC (rev 5316)
@@ -0,0 +1,147 @@
+DBRep_DrawableShape
+CASCADE Topology V1, (c) Matra-Datavision
+Locations 3
+1
+              1               0               0               0
+              0               1               0               0
+              0               0               1               5
+2  1 -1 0
+1
+              1               0               0               4
+              0               1               0               0
+              0               0               1               0
+Curve2ds 7
+1 6.2831853071795862 -6.2831853071795862 0 1
+1 0 -6.2831853071795862 0 1
+1 0 1.5707963267948966 1 0
+8 1.6653345369377348e-16 3.1415926535897931
+7 0 0  10 56 7  6.2831853071795916 0.97873451276921841  6.1489042135794509 0.97873451268533362  6.0146230247046333 0.97141404585454438  5.8836119286133908 0.95677466827328317  5.7591255260631442 0.93527328863274306  5.6434262122493237 0.90786399279022589  5.5362642745021731 0.8756338802195387  5.437181782501284 0.83945724614750361  5.3452301078868913 0.80012683039058174  5.2594764863445693 0.75828188140585095  5.0381764824154551 0.63778135974603356  4.9135229666353553 0.55505510526063517  4.8001403373782523 0.46917929048504448  4.6934712822549045 0.38204689055783092  4.590790226822719 0.29496254233890795  4.4895743204979226 0.20913706698411261  4.3879535228479654 0.12567535841299105  4.2841139328738791 0.045796977317877463  4.1765307343294591 -0.029120653967002627  3.9798301341867424 -0.14889580309271588  3.8928203398740235 -0.19658596678599333  3.8026495240033911 -0.23999638094303463  3.7090118359948976 -0.27844458634044711  3.6118106095600524 -0.3112238613948648  3.5112205
 34137101 -0.33761815609468615  3.4078314380798473 -0.35699149820088677  3.302645157305514 -0.36890977687802062  3.196794094605282 -0.37321085519203928  2.9331984952231389 -0.36512666481415762  2.7759704298441648 -0.34332264906095133  2.623301088475273 -0.30485103939645342  2.4785495957767125 -0.2512178329143353  2.3431967371143401 -0.1851859974249237  2.2156141592131462 -0.10942037453423836  2.0944392439268995 -0.026061745404149406  1.9774495381716406 0.062936079413589141  1.8622819719848362 0.15587741612512707  1.6876391405937508 0.29855345134486555  1.629109960765549 0.3466562435978538  1.5698808082094347 0.39508240948681594  1.5095283771661947 0.44360858626409183  1.4475730485043337 0.4919990058390592  1.3834726628200464 0.53999698017578335  1.3166029972589652 0.58731166555969838  1.2462293919435594 0.63359808845300136  1.1715035647953038 0.67843238771246817  1.0115949280965766 0.76414401228240481  0.92641245007416728 0.8050214886707181  0.83512437843819498 0.843393436472
 97937  0.73684421871439554 0.87863820003985893  0.63069778667704668 0.90999038497102447  0.51627045474015176 0.93660737491154578  0.39342964852403384 0.95745542187796673  0.26436602608464455 0.97164103915929445  0.13218295153934737 0.97873451268664435  4.1930483481222847e-16 0.9787345127692173
+ 1.6653345369377348e-16 11 0.78539816339745383 9 2.1598449493430012 9 3.1906800388021477 9 4.7369326729908714 9 5.5100589900852279 9 6.2831853071795862 11
+7 0 0  10 101 12  3.1415926535897927 1.5055939875750588  3.2278531271570641 1.5055939875211723  3.3141131394841223 1.505006160863664  3.398344112875384 1.5038306543277487  3.4785026801953789 1.5020924844531691  3.5530410803257837 1.4998443166587094  3.6213676690356804 1.4971504708897556  3.6835416590931347 1.4940730407238334  3.7398154825137366 1.4906667613105811  3.7906511447981486 1.4869797630620267  3.9268647046660785 1.4753210053997896  3.997999725430418 1.4666585706199839  4.0536797217500862 1.4573756373283686  4.0983964778133668 1.4476735413190909  4.1345891373930499 1.4376587999868207  4.1642937508877367 1.427415982063394  4.1888052817957941 1.416994857499958  4.2091582421053317 1.4064365386839199  4.226104513592162 1.3957695676849273  4.2675978950723517 1.3641821997807977  4.2843767393847241 1.3430244747916198  4.2948108943948684 1.3217054018322869  4.3007006095198452 1.3002925383065302  4.3032464663265273 1.2788352089082764  4.3032272111013299 1.2573674531464349  4.
 301139847836021 1.2359130366284716  4.2973972028331264 1.2144941734485246  4.2922701417265809 1.1931275028828137  4.2741839708352769 1.1318928400375323  4.2582959432178589 1.0921949701192752  4.2397413988115655 1.0528353114864331  4.2191194172133688 1.0138880947852158  4.1968380187463481 0.97542326383882028  4.1731544322334226 0.93750790623016655  4.148224898319131 0.90020811083281838  4.1221801182200624 0.86359169524567414  4.0950972666799155 0.82772723980130447  4.0179351267490393 0.73136195954747663  3.9658423023730549 0.67255762133591745  3.9110804617957671 0.61665001560631671  3.8537625153277384 0.56403375158134472  3.7939515217096611 0.51512271732478143  3.7317180770446305 0.47034800948955163  3.6671685967976595 0.43014644248982431  3.6004766513081585 0.39493886906691617  3.5319103052335423 0.36510174636202797  3.3566575454361836 0.30469633983728595  3.2480532226145442 0.28122171808854546  3.13714705145685 0.27154497671835998  3.0254828825127333 0.27632791280484525  2.
 9149091533035971 0.29569365357019706  2.8073410430224612 0.32899625377467601  2.7039466708956752 0.37501906258330564  2.6054575313319219 0.43236588715899416  2.512218218496562 0.49957791763715675  2.3807382285521657 0.61307501410072884  2.3383079341461221 0.65302053735957588  2.2973169707042871 0.69490250816916155  2.2578029542084552 0.73854692492168394  2.2198251514309959 0.78378463734770776  2.1834532391760151 0.83045344073907468  2.1488164492128816 0.87839702861092517  2.1161380806284433 0.92746373205594423  2.0857672877924953 0.97750501063252693  2.044967676088858 1.0537900619258322  2.0321604693768118 1.0794222720665929  2.0202552898934298 1.1052383930062661  2.0093885484049681 1.1312180148277549  1.9997563144715969 1.157339045079425  1.9916020485034096 1.183578267572011  1.9852858097690842 1.2099088205934094  1.9813421591504103 1.236298206059768  1.9805573507809187 1.2627059026552421  1.9865647654608101 1.3022402086550142  1.9897648644293817 1.3154054199736607  1.99436
 57746226944 1.3285491061613428  2.0006276123703777 1.3416604119486695  2.0088778545464772 1.35472648052736  2.0195520214824683 1.3677304237533767  2.0332392980695069 1.3806495814669932  2.0507551667093398 1.39345329259288  2.0733105161256331 1.4060960851517419  2.1176858625368413 1.4247002725993749  2.1342345905897369 1.4308416664636556  2.1527898345717196 1.436913133145884  2.1736466330158692 1.4429026881938021  2.1971660587902688 1.4487954500123625  2.2237817461819458 1.4545729262401743  2.2540195271843966 1.460211749005234  2.2885266484637001 1.4656816113468483  2.3280763640183642 1.4709425847956141  2.4188896801581103 1.4809422668211394  2.4701529005251359 1.4856809929551673  2.5280885733372997 1.4901062598801218  2.5935317196999677 1.4941543471359182  2.6673277859226801 1.4977444228716195  2.7498465885873884 1.500786174525274  2.8412253700953443 1.5031661284010625  2.9391579720686423 1.5047846476354607  3.040375362258557 1.5055939875118287  3.1415926535897967 1.50559398
 75750608
+ 1.6653345369377348e-16 11 0.098174770424676247 9 0.2914563496982569 9 0.66593940954085029 9 1.368095146745695 9 2.596867686854166 9 4.4400264970168761 9 5.3616059020982334 9 5.8223956046389027 9 6.0527904559092427 9 6.1679878815444145 9 6.2831853071795862 11
+8 3.1415926535897931 6.2831853071795862
 75750608
+Curves 3
+2 0 0 0 -2.4492935982947064e-16 -1 0 1 -2.4492935982947064e-16 0 0 0 1 6
+2 -1.1219512195121952 0 6.4024390243902438 0.62469504755442429 0 -0.78086880944303039 0.78086880944303039 0 0.62469504755442429 0 -1 0 5.7248921600238409
+Polygon3D 0
+PolygonOnTriangulations 7
+4 6 7 8 5
+p 1.25936677117254 1 7.2619198199488 7.45927375795736 7.65662769596592 7.85398163397448
+4 1 3 4 2
+2 2 5
+p 1e-05 1 0 6.28318530717959
+19 6 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 9
+p 1.25936677117254 1 1.66533453693773e-16 0.174532925199433 0.349065850398866 0.523598775598298 0.698131700797731 0.872664625997164 1.0471975511966 1.22173047639603 1.39626340159546 1.5707963267949 1.74532925199433 1.91986217719376 2.09439510239319 2.26892802759263 2.44346095279206 2.61799387799149 2.79252680319092 2.96705972839036 3.14159265358979
+19 1 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 2
+p 1.90926008587173 1 1.66533453693773e-16 0.174532925199433 0.349065850398866 0.523598775598298 0.698131700797731 0.872664625997164 1.0471975511966 1.22173047639603 1.39626340159546 1.5707963267949 1.74532925199433 1.91986217719376 2.09439510239319 2.26892802759263 2.44346095279206 2.61799387799149 2.79252680319092 2.96705972839036 3.14159265358979
+19 9 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 1
More information about the cgma-dev
