[cgma-dev] imprint mesh bug
Boyd Tidwell boyd at csimsoft.com
Wed Dec 28 14:44:58 CST 2011
The following commands:
     brick width 10
     brick width 6
     body 2 move x 8
     volume 1 2 size 1
     mesh volume 1 2
     imprint mesh body 1 2
cause a crash.  The same commands without the meshing works fine.
The actual failure occurs in
 void PartitionSurface::get_parents_virt( DLIList<TopologyBridge*>&
result_list )
On the assert in the following code, tmp_list.size() is zero.
    for( i = real_surf_shells.size(); i--; )
      tmp_list.clean_out();
      real_surf_shells.get_and_step()->get_parents_virt( tmp_list );
      assert(tmp_list.size() == 1);
      real_surf_vols.append(tmp_list.get());
A clue to the real problem may be revealed in the method called right
before the assert:
void OCCShell::get_parents_virt( DLIList<TopologyBridge*>& parents )
 for(int i = 0; i <  bodies->size(); i++)
    body = bodies->get_and_step();
    TopoDS_Compound* shape = body->get_TopoDS_Shape();             <----
added line
    if (shape ==
NULL)
<---- added line
continue;
<---- added line
    TopExp::MapShapesAndAncestors(*(body->get_TopoDS_Shape()),
                                     TopAbs_SHELL, TopAbs_SOLID, M);
    if (!M.Contains(*(get_TopoDS_Shell())))
         continue;
Previously I added the lines to check if "body->get_TopoDS_Shape()" was
returning a NULL pointer.  It seemingly fixed a number of problems. I wish
I'd written down the actual things that the change fixed.  This might just
be a band-aid that hides a deeper problem but my tests run much better with
the new code in place.  Because the existing code doesn't check for a null
pointer, there seems to be an assumption that it will never be null so the
null pointer could be the real problem.  I don't have enough understanding
of the code to know what is correct.
Good Luck and thanks in advance,
  - Boyd
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20111228/4047bde1/attachment.htm>
More information about the cgma-dev mailing list
