[cgma-dev] OCC Build error:
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Thu Dec 22 21:02:48 CST 2011
No, it is not, I think it is overloaded by //! Make a face from a Surface. <br> Standard_EXPORT BRepBuilderAPI_MakeFace(const Handle(Geom_Surface)& S); do you have this function in your hxx file? Again, what version of OCC do you use? Iulian ----- Original Message -----
| Hello Iulian,
| It seems to me that the latest version of OpenCascade has some changes
| in the Interface and in the header file, I could
| not see the function with the given arguments.
| Who can help me quickly in fixing this problem ?
| csv
| make[4]: Entering directory `/home/csverma/ITAPS/cgm/trunk/geom/OCC'
| /bin/bash ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H
| -I. -I../.. -I../../geom/parallel -I../../geom -I../../itaps
| -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC
| -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -I../../util
| -I../../geom -I/home/csverma/Software/Mesh/OpenCascade/inc -D_OCC64
| -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall
| -pipe -pedantic -g -MT OCCModifyEngine.lo -MD -MP -MF
| .deps/OCCModifyEngine.Tpo -c -o OCCModifyEngine.lo OCCModifyEngine.cpp
| libtool: compile: g++ -DHAVE_CONFIG_H -I. -I../..
| .deps/OCCModifyEngine.Tpo -c OCCModifyEngine.cpp -o OCCModifyEngine.o
| OCCModifyEngine.cpp: In member function ‘virtual Surface*
| OCCModifyEngine::make_Surface(Surface*, CubitBoolean) const’:
| OCCModifyEngine.cpp:716:56: error: no matching function for call to
| ‘BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(Handle_Geom_RectangularTrimmedSurface&)’
| /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:175:21:
| note: candidates are:
| BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const TopoDS_Face&,
| const TopoDS_Wire&)
| /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:132:21:
| note: BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const
| Handle_Geom_Surface&, const TopoDS_Wire&, Standard_Boolean)
| /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:130:21:
| gp_Torus&, const TopoDS_Wire&, Standard_Boolean)
| /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:128:21:
| gp_Sphere&, const TopoDS_Wire&, Standard_Boolean)
| /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:126:21:
| note: BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Cone&,
| /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:124:21:
| gp_Cylinder&, const TopoDS_Wire&, Standard_Boolean)
| /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:122:21:
| note: BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Pln&,
| /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:120:21:
| To: Chaman Singh Verma <csv610 at yahoo.com>
| Cc: CGMA Development <cgma-dev at mcs.anl.gov>
| Sent: Thursday, December 22, 2011 3:09 PM
| Subject: Re: OCC Build error:
| Sorry, somebody else may have a clue.
| Maybe try to do a clean build of CGM?
| What version of OCC are you using? I am using 6.5.0, but I had don't
| have build errors with 6.5.1 either
| (I do have a make check error now "imprint_bug", but it is unrelated
| to your error)
| Iulian
| | Yes, I checked it. It is in the directory and I think OCC
| | installation
| | is correct. It didn't give any error.
| | csv
| | Sent: Thursday, December 22, 2011 2:26 PM
| | Hi Chaman,
| | do you have the file
| | in the
| | folder?
| | Iulian
| | | Hi Chaman,
| | | I don't get that error.
| | | Is your OCC build OK? Did you patch it?
| | | This is what I get when compiling OCCModifyEngine.cpp in my build
| | | area:
| | | This in on my 32 bit laptop.
| | | Iulian
| | | -DHAVE_CONFIG_H
| | | -I../../geom -I/home/iulian/3rdparty/lib/occ/inc -DHAVE_IOSTREAM
| | | -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe
| | | -pedantic
| | | -g
| | | -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c -o
| | | -pedantic
| | | -g
| | | OCCModifyEngine.cpp -fPIC -DPIC -o .libs/OCCModifyEngine.o
| | | -pedantic
| | | -g
| | | OCCModifyEngine.cpp -o OCCModifyEngine.o >/dev/null 2>&1
| | | mv -f .deps/OCCModifyEngine.Tpo .deps/OCCModifyEngine.Plo
| | | /bin/bash ../../libtool --tag=CXX --mode=link g++ -Wall -pipe
| | | -pedantic -g -o libcubit_OCC.la OCCShapeAttributeSet.lo
| | | OCCAttribSet.lo OCCBody.lo OCCCoEdge.lo OCCCoFace.lo OCCCurve.lo
| | | OCCHistory.lo OCCLoop.lo OCCLump.lo OCCModifyEngine.lo OCCPoint.lo
| | | OCCQueryEngine.lo OCCShell.lo OCCSurface.lo OCCDrawTool.lo
| | | -L/home/iulian/3rdparty/lib/occ/lib -lTKSTL -lTKSTEP -lTKSTEP209
| | | -lTKSTEPAttr -lTKSTEPBase -lTKXSBase -lTKIGES -lTKXSBase -lTKBinL
| | | -lTKLCAF -lTKCDF -lTKCAF -lTKHLR -lTKOffset -lTKShHealing
| | | -lTKFillet
| | | -lTKFeat -lTKBool -lTKBO -lTKPrim -lTKMesh -lTKTopAlgo
| | | -lTKGeomAlgo
| | | -lTKBRep -lTKGeomBase -lTKG3d -lTKG2d -lTKMath -lTKernel -ldl -lm
| | | libtool: link: rm -fr .libs/libcubit_OCC.a .libs/libcubit_OCC.la
| | | libtool: link: ar cru .libs/libcubit_OCC.a
| | | .libs/OCCShapeAttributeSet.o .libs/OCCAttribSet.o .libs/OCCBody.o
| | | .libs/OCCCoEdge.o .libs/OCCCoFace.o .libs/OCCCurve.o
| | | .libs/OCCHistory.o .libs/OCCLoop.o .libs/OCCLump.o
| | | .libs/OCCModifyEngine.o .libs/OCCPoint.o .libs/OCCQueryEngine.o
| | | .libs/OCCShell.o .libs/OCCSurface.o .libs/OCCDrawTool.o
| | | libtool: link: ranlib .libs/libcubit_OCC.a
| | | libtool: link: ( cd ".libs" && rm -f "libcubit_OCC.la" && ln -s
| | | "../libcubit_OCC.la" "libcubit_OCC.la" )
| | | | Hello Iulian
| | | | I am trying to build CGM with OCC now. I get the following
| | | | errors
| | | | Could you help ?
| | | | csv
| | | | Making all in OCC
| | | | -DHAVE_CONFIG_H
| | | | -D_OCC64
| | | | -Wall
| | | | OCCModifyEngine.cpp
| | | | -D_OCC64
| | | | -Wall
| | | | OCCModifyEngine.o
| | | | to
| | | | TopoDS_Face&,
| | | | const TopoDS_Wire&)
| | | | gp_Cone&,
| | | | gp_Pln&,
| | | | /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:115:21:
| | | | Handle_Geom_Surface&, Standard_Real, Standard_Real,
| | | | Standard_Real,
| | | | Standard_Real, Standard_Real)
| | | | /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:112:21:
| | | | gp_Torus&, Standard_Real, Standard_Real, Standard_Real,
| | | | Standard_Real)
| | | | /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:110:21:
| | | | gp_Sphere&, Standard_Real, Standard_Real, Standard_Real,
| | | | Standard_Real)
| | | | /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:108:21:
| | | | gp_Cone&,
| | | | Standard_Real, Standard_Real, Standard_Real, Standard_Real)
| | | | /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:106:21:
| | | | gp_Cylinder&, Standard_Real, Standard_Real, Standard_Real,
| | | | Standard_Real)
| | | | /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:104:21:
| | | | gp_Pln&,
| | | | /home/csverma/Software/Mesh/OpenCascade/inc/BRepBuilderAPI_MakeFace.hxx:102:21:
| | | | Handle_Geom_Surface&, Standard_Real)
| | | | Cc: meshkit-dev at mcs.anl.gov
| | | | Sent: Sunday, December 18, 2011 9:50 PM
| | | | Subject: Re: Mesquite Cubit tangling
| | | | Hello Chaman,
| | | | Sorry, I don't know.
| | | | There is no easy solution; One solution would be to match
| | | | exactly
| | | | mesquite version that cubit is using.
| | | | So if you need mesquite and cubit together, and if cubit has the
| | | | full
| | | | capabilities of mesquite, then we should eventually link only
| | | | against
| | | | cubit libraries.
| | | | Unfortunately, I don't know what cubit has from mesquite. Also,
| | | | probably itaps interfaces in mesquite are not part of cubit.
| | | | We can see what methods from mesquite are in cubit library (and
| | | | we
| | | | know that Mesquite namespace is Mesquite2 in cubit). We should
| | | | compare
| | | | that list with a current mesquite library, and see maybe where
| | | | are
| | | | the
| | | | differences in number of parameters, etc. Then modify the
| | | | mesquite
| | | | source code, to match or to eliminate discrepancies.
| | | | Right now, I am using occ, and it works pretty well. Of course,
| | | | I
| | | | have
| | | | a problem that irel and igeom in mesquite cannot see the FBiGeom
| | | | yet,
| | | | so I may have to understand/modify mesquite anyway, to make it
| | | | work.
| | | | Iulian
| | | | | Hello Iulian
| | | | | I am again facing problems because of Mesquite and Cubit
| | | | | together.
| | | | | Which one we should add first ?
| | | | | If I add Mesquite first then I get double free errors, and if
| | | | | I
| | | | | do
| | | | | the
| | | | | cubit first, then I get segmentation error ?
| | | | | csv
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20111222/f552b296/attachment.htm>
More information about the cgma-dev
