[cgma-dev] r5271 - cgm/trunk/itaps
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Thu Dec 22 11:00:09 CST 2011
Hi Jane, The test is using a "test.occ" file that can' be read when cgm is built with ACIS or CUBIT. I think that it should be taken out of the Makefile.am for ACIS or CUBIT cases, or replaced with a different test file, using ifdefs or something similar. We can ignore it for the time being, have a nice vacation! Thanks, Iulian ----- Original Message -----
| Author: janehu
| Date: 2011-12-21 10:50:25 -0600 (Wed, 21 Dec 2011)
| New Revision: 5271
| Added:
| cgm/trunk/itaps/copy_attrib.cpp
| Modified:
| cgm/trunk/itaps/Makefile.am
| Log:
| Added testcase from Rajeev for copy attributes.
| Modified: cgm/trunk/itaps/Makefile.am
| --- cgm/trunk/itaps/Makefile.am 2011-12-19 18:23:41 UTC (rev 5270)
| +++ cgm/trunk/itaps/Makefile.am 2011-12-21 16:50:25 UTC (rev 5271)
| @@ -8,14 +8,14 @@
| TESTS = test_edge_orient
| if build_ACIS
| - TESTS += testgeom
| + TESTS += testgeom copy_attrib
| else
| if WITH_CUBIT
| - TESTS += testgeom
| endif
| endif
| if build_OCC
| - TESTS += testgeom_occ
| + TESTS += testgeom_occ copy_attrib
| endif
| @@ -66,6 +66,8 @@
| chaman_SOURCES = chaman.cc
| +copy_attrib_SOURCES = copy_attrib.cpp
| if USE_MPI
| check_PROGRAMS += partest
| partest_SOURCES = partest.cpp
| @@ -94,7 +96,7 @@
| EXTRA_DIST = testgeom.sat size.sat
| -CLEANFILES = iGeom-Defs.inc testout.sat mmgr.log step_import.log
| +CLEANFILES = iGeom-Defs.inc testout.sat mmgr.log step_import.log
| test.occ
| DISTCLEANFILES = iGeom_FCDefs.h
| FPFX=iGeom
| Added: cgm/trunk/itaps/copy_attrib.cpp
| --- cgm/trunk/itaps/copy_attrib.cpp (rev 0)
| +++ cgm/trunk/itaps/copy_attrib.cpp 2011-12-21 16:50:25 UTC (rev 5271)
| @@ -0,0 +1,175 @@
| +#include "iGeom.h"
| +#include <vector>
| +#include <iostream>
| +#include <stdio.h>
| +#include <fstream>
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20111222/105ea591/attachment.htm>
More information about the cgma-dev
