[cgma-dev] Fwd: Re: Problems compiling Lasso with CUBIT-linked	CGM	and MOAB
    James Porter
    jvporter at wisc.edu
    Wed Dec 14 11:54:51 CST 2011
On Wed, 2011-12-14 at 09:13 -0600, Tim Tautges wrote:
> [Forwarding in case others are seeing issues...]
> -------- Original Message --------
> Subject: Re: Problems compiling Lasso with CUBIT-linked CGM and MOAB
> Date: Wed, 14 Dec 2011 09:12:54 -0600
> From: Tim Tautges <tautges at mcs.anl.gov>
> To: Michael Fladerer <fladerer at fnb.tu-darmstadt.de>
> Are you grabbing the nightly source tarballs for CGM, Lasso, and MOAB?  The error you're having below looks like your
> Lasso is out of date.
Since it appears that you're on a pretty bleeding-edge version of MOAB,
you should be on an equally bleeding-edge version of Lasso.
Specifically, the interfaces to iMesh_initEntIter and
iMesh_initEntArrIter changed about a week ago, and so Lasso was also
updated to reflect this. It looks like you're using a version of Lasso
from before last week, which is causing the issues.
- Jim
More information about the cgma-dev
