[cgma-dev] r5255 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Dec 9 12:35:34 CST 2011
Author: janehu
Date: 2011-12-09 12:35:34 -0600 (Fri, 09 Dec 2011)
New Revision: 5255
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Fixed testcase mcnp2cad/INP-complement, passed cgm tests and mcnp2cad cone, cone2, cone3, transform6, hexlat.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2011-12-09 15:25:36 UTC (rev 5254)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2011-12-09 18:35:34 UTC (rev 5255)
@@ -2204,7 +2204,7 @@
//list of face on from_shape that has been imprinted
DLIList<TopoDS_Face*> from_faces;
- CubitBoolean need_1_split = CUBIT_FALSE;
+ //CubitBoolean need_1_split = CUBIT_FALSE;
while( more_face)
TopoDS_Face from_face,tool_face;
@@ -2477,8 +2477,10 @@
if(fabs(-after_mass + orig_mass) > TOL && after_mass > TOL)
return 1;
else
need_1_split = CUBIT_TRUE;
//have to use boolean operation, see
//http://www.opencascade.org/org/forum/thread_20672/ for more info
@@ -2723,9 +2725,10 @@
CubitBox* pbox = new CubitBox(box);
bs.append(pbox);
if(size > 1)
bs.append((CubitBox*) NULL);
for(int i = 0; i < size-1; i++)
@@ -2934,8 +2937,10 @@
TopoDS_Face* topo_face = new TopoDS_Face(from_face);
from_faces.append(topo_face);
if (need_1_split)
break;
@@ -3531,35 +3536,8 @@
//for cylinder overlapping cases, doing boolean operation is necessary for
//now. 10/25/11
BodySM* tool_copy = copy_body(from_body_list[j%size]);
More information about the cgma-dev
