[cgma-dev] r5219 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Nov 18 12:37:45 CST 2011
Author: janehu
Date: 2011-11-18 12:37:42 -0600 (Fri, 18 Nov 2011)
New Revision: 5219
Modified:
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
Log:
Fixed the mcnp2cad/cone, cone2, cone3 cases, it passed cgm make check, rgg/assygen 7 is still working at speed 9.9 min now. Since it introduces boolean operation for imprint, it's pending for Tim's approval for possible body pointer changes.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2011-11-17 00:32:00 UTC (rev 5218)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2011-11-18 18:37:42 UTC (rev 5219)
@@ -554,9 +554,28 @@
//set the Shells
TopTools_IndexedMapOfShape M;
TopExp::MapShapes(old_shape, TopAbs_SOLID, M);
+ TopTools_IndexedMapOfShape M_new;
+ TopExp::MapShapes(new_shape, TopAbs_SOLID, M_new);
TopTools_ListOfShape shapes;
TopoDS_Shape shape;
+ CubitBoolean updated = CUBIT_FALSE;
+ if(!old_shape.IsNull() && old_shape.ShapeType() == TopAbs_COMPOUND &&
+ !new_shape.IsNull() && new_shape.ShapeType() == TopAbs_COMPOUND &&
+ !old_shape.IsSame(new_shape) && M.Extent() == M_new.Extent())
+ //By updating underling solids, shells etc., the old_shape will get changed.
+ //trying to make sure the the number of each entity in the old and new
+ //shapes are the same, which means that nothing is delete, that we can
+ //update the map here. Otherwise, when deleting solids, it'll delete the
+ //the old body and create new body. This is Ok for general boolean operation //except imprint when booleans are called, usually the original body are
+ // supposed to be kept.
+ updated = CUBIT_TRUE;
+ OCCQueryEngine::instance()->update_OCC_map(old_shape, new_shape);
+ DLIList<int> new_solid_nums;
+ DLIList<int> unfound_nums;
for(int ii=1; ii<=M.Extent(); ii++)
TopoDS_Solid solid = TopoDS::Solid(M(ii));
@@ -588,10 +607,38 @@
else if(op->IsDeleted(solid))
- TopTools_IndexedMapOfShape M_new;
- TopExp::MapShapes(new_shape, TopAbs_SOLID, M_new);
if (M_new.Extent()== 1)
shape = M_new(1);
+ else if(M_new.Extent() > 1)
+ GProp_GProps myProps;
+ BRepGProp::VolumeProperties(solid, myProps);
+ double bf_mass = myProps.Mass();
+ gp_Pnt old_center = myProps.CentreOfMass();
+ CubitBoolean found = CUBIT_FALSE;
+ for(int l = 1; l <= M_new.Extent(); l++)
+ BRepGProp::VolumeProperties(M_new(l), myProps);
More information about the cgma-dev
