[cgma-dev] [Fathom] cgm make check with occ
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Fri Sep 16 17:02:46 CDT 2011
Hi Jane,
Thank you very much.
So 6.5 version is fine now, I patched the file and recompiled. There are no errors in make check, at least on my machine!
It took a long time, somehow the compiler decided to compile everything in occ, although only one file was modified.
Still, I had to apply the patch manually (in the sense that I edited the file manually); the patch file contains references to you home directory
--- src/Extrema/Extrema_ExtPS.cxx 2011-04-11 13:06:46.000000000 -0500
+++ /home/jhu/OpenCASCADE6.5.0/ros/src/Extrema/Extrema_ExtPS.cxx 2011-04
-09 14:13:13.000000000 -0500
Anyway, it works now.
I should have realized that you modified the patch file four months ago. I should have patched and rebuild occ at that time. Also, maybe your commit message should have suggested that occ needs to be recompiled.
Have a good weekend!
Iulian
----- Original Message -----
	Hi, Iulian,
I double checked /homes/fathom/3rdparty/occ/OpenCASCADE6.3.0/src/OpenCASCADE6.3.0/ros/src/BRepBuilderAPI/BRepBuilderAPI_Collect.cxx, it's the same problem: need to be patched.
Except this one, trunk cgm on occ6.5 and occ6.3 should both pass make check.
Please let me know how it turns out.
Thanks.
Jane
--- On Thu, 9/15/11, Iulian Grindeanu <iulian at mcs.anl.gov> wrote:
Subject: Re: [Fathom] cgm make check with occ
To: "Jiangtao Hu" <jiangtao_ma at yahoo.com>
Cc: "CGMA Development" <cgma-dev at mcs.anl.gov>, "James Porter" <jvporter at wisc.edu>
Date: Thursday, September 15, 2011, 2:02 PM
Hi Jane,
So maybe the occ build is wrong
I built occ 6.5 on fathom space:
/home/fathom/3rdparty/occ/OpenCASCADE6.5.0
the configuration log file is here:
home/fathom/3rdparty/occ/OpenCASCADE6.5.0/ros/config.log
The installation is at
/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc
It was built on my desktop, iulian-desktop
gnep buildbot is using the same build
Do you have an mcs account? Otherwise how can you access my machine ? Or gnep?
Iulian
> Hi, Iulian,
> What is the build machine's name? I tried to use non-debug mode on my
> machine, it still passed. I'd like to access your machine to debug
> then. Thanks.
> Jane
> --- On Thu, 9/15/11, Iulian Grindeanu < iulian at mcs.anl.gov > wrote:
> From: Iulian Grindeanu < iulian at mcs.anl.gov >
> To: "Jiangtao Hu" < jiangtao_ma at yahoo.com >
> Cc: "CGMA Development" < cgma-dev at mcs.anl.gov >, "James Porter"
> < jvporter at wisc.edu >
> Date: Thursday, September 15, 2011, 1:01 PM
> > Hi, Iulian,
> > Those missing files are only for 10.2 cgm, 12.2 cgm has already have
> > them. Can you let me know where the modify failed? Thanks.
> > Is the nightly build and check for cgm still on? Can James confirm
> > it?
> > Thanks.
> > Jane
> Hi Jane,
> The backtrace is
> (gdb) backtrace
> #0 0x00007fffee5c5a75 in *__GI_raise (sig=<value optimized out>) at
> ../nptl/sysdeps/unix/sysv/linux/raise.c:64
> #1 0x00007fffee5c95c0 in *__GI_abort () at abort.c:92
> #2 0x00007ffff00378e5 in __gnu_cxx::__verbose_terminate_handler() ()
> from /usr/lib/libstdc++.so.6
> #3 0x00007ffff0035d16 in ?? () from /usr/lib/libstdc++.so.6
> #4 0x00007ffff0035d43 in std::terminate() () from
> #5 0x00007ffff0035e3e in __cxa_throw () from /usr/lib/libstdc++.so.6
> #6 0x00007ffff03446ed in Standard_NoSuchObject::Throw() const () from
> /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so.0
> #7 0x00007ffff0344bc3 in Standard_NoSuchObject::Raise(char const*) ()
> from
> #8 0x00007ffff232d78d in
> BRepBuilderAPI_ModifyShape::ModifiedShape(TopoDS_Shape const&) const
> () from
> /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so.0
> #9 0x00007ffff231cd43 in
> BRepBuilderAPI_GTransform::ModifiedShape(TopoDS_Shape const&) const ()
> from
> #10 0x000000000043c6aa in OCCLump::update_OCC_entity (this=0xcce470,
> aBRepTrsf=0x7fffffffcc90, op=0x0) at OCCLump.cpp:378
> #11 0x000000000042de01 in OCCBody::update_OCC_entity (this=0xcd40e0,
> aBRepTrsf=0x7fffffffcc90, op=0x0) at OCCBody.cpp:511
> #12 0x000000000042da4d in OCCBody::scale (this=0xcd40e0,
> scale_factor_x=1, scale_factor_y=2, scale_factor_z=5) at
> OCCBody.cpp:450
> #13 0x00000000004556da in OCCQueryEngine::scale (this=0xcc14c0,
> body=0xcd40e0, f=...) at OCCQueryEngine.cpp:3516
> #14 0x00000000004870ce in OCCModifyEngine::scale (this=0xcc1600,
> body=@0x7fffffffd0b0, factors=...) at OCCModifyEngine.cpp:8891
> #15 0x00000000006ea8c2 in GeometryModifyTool::scale (this=0xcbefd0,
> body=@0x7fffffffe1c8, factors=..., check_to_transform=true,
> preview=false) at GeometryModifyTool.cpp:6779
> #16 0x0000000000421345 in make_Point () at modify.cpp:146
> #17 0x0000000000420b0f in main (argc=1, argv=0x7fffffffe3c8) at
> modify.cpp:55
> occ 6.5 is not build with debug option on our machines, so it is
> harder to debug.
> Do you build occ with "enable-debug" on your machine?
> Iulian
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20110916/5144bd3a/attachment.htm>
More information about the cgma-dev
